7500K HID bulbs......
Old Oct 25, 2005 | 09:05 PM
StealthTL's Avatar
Metatron
Bought some 7500K D2Sb bulbs from member "RotaryRasp", and thought I'd post some comparison pics.....
(The 7500ks sure make the little running lights look yellow - )
First pic is from a high angle, as you would see from the sidewalk, you can see the bluer tint in the housing.
Second is as you would see on the road, oncoming - bluish, actually has less "dazzle".
Third is still low-beam but from road level, and demonstrates the reduced output, even at only 7500*K, of the bluer light. I would put it at about 70% of the stock illumination.
S
Attached Thumbnails 7500K HID bulbs......-dcp_1290s.jpg   7500K HID bulbs......-dcp_1285s.jpg   7500K HID bulbs......-dcp_1288s.jpg
Old Oct 26, 2005 | 07:14 AM
VASasha's Avatar
I see what you mean, but how is it possible?
Arn't the stock lights only 4000k? Shouldn't the new blue ones be brighter?
Old Oct 26, 2005 | 08:08 AM
Asmoran's Avatar
Higher K = less bright
Old Oct 26, 2005 | 10:43 AM
Chrisbert's Avatar
The K is Kelvins for color temperature. It is not necessarily related to Lumens.
Old Oct 26, 2005 | 10:46 AM
Asmoran's Avatar
not necesssarily, but for the most part the higher the K the less lumens you get.
Old Oct 26, 2005 | 11:17 AM
SantozRx8's Avatar
Raccoons SUCK!
less light but a very tight color, make the bmw and maxima drivers cringe :P lol
Old Oct 26, 2005 | 12:36 PM
Gerael's Avatar
Rexella's Daddy
i'm a little confused... is this the high beams?
cuz low beams are xenon unless you didn't get that package?
Old Oct 26, 2005 | 12:43 PM
KYLiquid's Avatar
Oil Injection
wow, thats a 7500K HID against the STOCK HIDs?
Maby its just the way they show up in the photo, but my stock HIDs look a lot blue than that, those look like halogens
Old Oct 26, 2005 | 12:48 PM
StealthTL's Avatar
Metatron
D2s.....
Yes, these are 35 watt D2S HID low-beam "capsules", same as stock, but higher K, bluer, and with less actual lumens.
They sell halogen bulbs by their Kelvin rating too, but these aint no $20 set of blue glass crap!
I am sticking with them, (I put the other side in, obviously!) I like the color, and they actually seem brighter because the beam is blue, it doesn't get lost in the ambient - you can pick the pattern out on the road. Should look awesome on snow!
S
Old Oct 26, 2005 | 12:59 PM
BIU's Avatar
BIU
how much of a hassle was it to switch out the HID bulbs?
took off the front bumper?
Old Oct 26, 2005 | 01:05 PM
StealthTL's Avatar
Metatron
Hassles....
No hassle at all - jacked up the side, took off the front wheel, removed 6-8 of the twist lock plastic nut thingies to get to the back of the projector, then twist off the cover, twist off wiring, unclip capsule - done!
Took ten minutes for the second side, using a flashlight! Didn't even take the wheel off, (but should have, it would have been easier!).
S
Old Oct 26, 2005 | 01:31 PM
Gerael's Avatar
Rexella's Daddy
mine dont look so yellow... and from inside... the beam is really whitish/blue tint color
really no hint of yellow
Old Oct 26, 2005 | 01:49 PM
Rotary Rasp's Avatar
503wtq Boosted Bimmer
I'm glad you like them! One thing I really liked about those bulbs is when you're driving at night, look at how they lght up reflective signs....you'll notice the signs kinda glow. Very cool.
Old Oct 26, 2005 | 01:58 PM
Here are some pics I took when I had my 8500K bulbs. The 8500K produced even less light.
Old Oct 26, 2005 | 02:03 PM
KYLiquid's Avatar
Oil Injection
S
I didnt mean your new HIDs look like halogens, I was saying that those 7500K next to the stock HIDs make the stock ones look like yellow halogens.....what an improvment. That should look really mean coming down the street!
Old Oct 26, 2005 | 02:33 PM
Nubo's Avatar
Lubricious
It depends on what you mean by "improvement". If your goal is to be able to see as well as possible during night driving, then reduction in output and poorer color rendition is hardly an improvement.
Old Oct 26, 2005 | 03:02 PM
Gerael's Avatar
Rexella's Daddy
i'm gonna have to check my lights tonight....
but my xenons look really white/blue tint... i don't know how it coul dlook that yellow in the picture...
am i missing something? is that hid for the non xenon kit?
Old Oct 26, 2005 | 03:31 PM
StealthTL's Avatar
Metatron
RaspGuy....
Wow! Those 8500ks really DO look purple!
I'm thinking the 7500k mark will be the cutoff for me - anything higher would be "too much"!
I DID notice the reflective sign thing, last night - I was approaching a railroad crossing, and even though the beams were nicely down on the tracks, the actual signs seemed to light up in blue! KEWL!
Thanks again, RaspGuy!
S
Old Oct 26, 2005 | 03:50 PM
Gerael's Avatar
Rexella's Daddy
anyone know a good bulb to chang eout the stock high beams???
they're too yellow and don't match the hid at all...
Old Oct 26, 2005 | 04:19 PM
StealthTL's Avatar
Metatron
Hi Beams.....
I went that route, and regretted it - in the case of the halogen H9 hi-beams, the only way to "match" would be to select bulbs with dark blue quartz bulbs, or even worse, a dark blue coating. The blue "glass" REALLY restricts the amount of available light - I swear, when I hit the hi-beams, it actually got DARKER!
There is really no need to match them both, where will you be cruising, with your hi beams on ? Since they are so bright, you can't look directly at them anyway.
For more light, the best (and probably only) way would be a higher wattage, the stocks are 65 watt, but this brings up fuse, wiring and warranty issues.
I have plans (always!) for HID hi beams, but the kit I have is for 9006 bulbs, so some adaptation is required. In Canada we have daytime running lights, which would need to be removed/bypassed, the HIDs would not like the "half-voltage" supplied by the DRL system!!
S
Old Oct 26, 2005 | 04:47 PM
Gerael's Avatar
Rexella's Daddy
well there are lots of places where you would want to run high beams... we don't have much street lights in some areas.... and its like all woody and forresty and stuff.. haha
the problem i see with xenons.. is that the low beam is so bright... that anything beyond the edge of the xenon is just black.... i've been trying to figure out
1) do my auto levels work??
2) should i readjust beam height....
1) i do'nt know how to check
2) i know the main part of the beam is well below the trunk line of most passenger cars... and not even close to getting into suv's... but i also know that people think i'm high beaming them at times... haha... i love xenon.. so... i'm still trying to decide whether to move up a little or not
therefore in the mean time... i would like to have high beams that just match color.. os its not so yellow
haha... cuz u can tell from the inside when you flip em on..
Old Oct 26, 2005 | 05:17 PM
dopeyxhj's Avatar
don't u think ??"stock light is Bright ENOUGH" =)
Old Oct 27, 2005 | 02:44 PM
Nubo's Avatar
Lubricious
HIDs and "less-yellow" aren't necessarily better
http://www.danielsternlighting.com/t...dvantages.html
Old May 3, 2006 | 12:01 AM
zenmoused's Avatar
the stig is my hero
I read that Audi and BMW use the same type of bulbs, same color temp and everything as our 8's, but the housing is different, and thus produces that beautiful blue color with no sacrifice of light output. Anybody have any idea how we could do this to our cars?
Old May 3, 2006 | 11:10 AM
Hightshoe's Avatar
'05 Titanium 6sp
Your lights are fine. This has been discused many times. There are factory set so that you dont blind oncoming traffic.
arexatemate
Oct 9, 2015 06:23 PM
wayloco
Sep 1, 2015 09:03 PM
beastman_5
Aug 30, 2015 10:22 AM
