Too Rich Problem??
Old Oct 24, 2005 | 08:40 PM
OfficerFarva's Avatar
Too Rich Problem??
I'm wondering if since imy car is most likely running so rich is why it bogs down if i give more than a 1/4 throttle. Could this be b/c it's running rich and drowning out the spark plugs when more fuel is required if i give more than 1/4 throttle? At half throttle it acts like it wants to go and lurhces and hits a flat spot, then sputters off backfires like a burst fire sub machine gun! Also, in the mornings or after the car has sat for a while it takes longer to start up. It sounds like it tries to turn over but the spark when i checked it looked a little weak, which gives me better reason to think the spark plugs may be partially damaged from the flooding. anyway, jw if my thoughts on the spark plugs make any sense.
Old Oct 24, 2005 | 11:55 PM
What color were the plugs?
Old Oct 25, 2005 | 02:14 PM
MadDog's Avatar
Consiglieri
sounds to me like "1/4 throttle" is probably when you go into boost. Do you have a boost gauge? positive pressure is when the emanage kicks, pumping in more fuel, which for you probably means way too rich. You are probably misfiring, does the CEL blink for a second and then stop?
Old Oct 25, 2005 | 03:17 PM
no cel blinks, just alot of backfires. I'm not driving it much and i will have sum info tomorrow, cus it should go to the shop to try and lean it out. I'll let yall know whats goin on as soon as i find out.
theblinkof
Oct 4, 2023 05:24 PM
Digitz0070
55
Jul 25, 2017 08:40 PM
Zube6115
Sep 30, 2015 12:57 PM
XianUnix
Sep 29, 2015 03:48 PM
tommy26Germany
Sep 29, 2015 10:33 AM
