Scary at 6000 and up!
Old Oct 24, 2005 | 12:31 PM
SlowLude's Avatar
Now don't get me wrong... I redline my car at least once a week. My old car was a Prelude and I redlined that thing on daily basis. But for some reason, when I reach the 6000-9000rpm, it freaks me out a bit. I always think the engine is gonna rip apart. Maybe its the increasing sound or the vibration.. Or maybe I just care about my car too much to push it all the way? Does anyone else feel like that too?
Old Oct 24, 2005 | 12:39 PM
sunilseru's Avatar
I am with you on this one. Never felt nervous redlining my RSX Type S. The car felt like a rock. I am just not comfortable doing the same with my RX-8. Maybe because of too many blown up engine stories
Old Oct 24, 2005 | 12:40 PM
NgoRX8's Avatar
I feel nervous to redline my car because I saw a cop follow me.
Old Oct 24, 2005 | 12:41 PM
RX-Hachi's Avatar
6000 is when all the fun begins. I love the sound of the engine at that range. Mine only sounds louder, but still very smooth. I rev to redline at least twice a day, once a week just won't cut it.
Old Oct 24, 2005 | 12:45 PM
RX Renesis's Avatar
umm... weird how u guys get scared relining this car... and as for vibration... i think ur not suppose to notice any vibration at all... many people even coment on how it doesn't vibrate at all when reaching rpms of 6000+... on my car it u can really feel it vibrate and working hard when relining... so kinda weird how u guys get scared of it...
Old Oct 24, 2005 | 12:48 PM
Dragonrider's Avatar
Of the Black Dragon
Thumbs up Try not to worry yourself
Try to remember that the rotary is not a piston engine, and that when the tac reads 9K the rotors are only doing 3k. You would have to read 21K on the tac to have the rotors turning over 7K.
If you think about it, that is why you see the power band on the rotary start around 6K because the rotors are at 2K. That is the same RPM on many piston engines when they start to develop their initial power.
On the track, if you don't keep the RPM between 6K and redline, you get left in the dust.
Some of us are looking to raise the RPM limit for that very reason. At 10K the rotors are only at 3300K. The only thing that is high revving is the crankshaft.
That might put a little persective on the RPM issue regarding the rotary engine for you.
Old Oct 24, 2005 | 12:52 PM
8_is_enuf's Avatar
I get no vibration at all. I feel better about this car at redline than any other car I've ever owned at 75% of redline.
Old Oct 24, 2005 | 12:54 PM
StewC625's Avatar
Insanely Yellow
Never, but never.
Old Oct 24, 2005 | 12:57 PM
ZoomZoomH's Avatar
Mulligan User
you're just scared, period
my car LOVES to visit the redline, and i oblige regularly :D
Old Oct 24, 2005 | 12:59 PM
yz007's Avatar
A turbo what?
scared???
AHHAHAHA.... Sorry, I would'nt be scared, I think i keep my car in that rpm range all the time, I have about 57k miles on mine already, And I drive the hell out of it, I shift right before the rev limiter kicks in about 9200 rpm, I have had no problems with this car. I have blown up many rotarys but never because of redlining it. Mainly they had cooling problems, and or were boost/tuning related.
Enjoy your car, its made to rev
Jesse
Old Oct 24, 2005 | 01:18 PM
Sapphonica's Avatar
PingMobile
The tach is off by ~500 rpms up high anyway, so 9k on the tach is actually about 8500.
When I rev the car, I never shift 'till I hear the 'beep'.
You're much more likely to kill a piston engine by overrevving it than a rotary. All the rotary's motive parts go roundy-roundy (or direct rotational action, if you will). In a piston engine the pistons go up & down & also lifters/valves, both of which are common failure points when those engines 'blow'.
I'll bet the Renesis engine could rev @ 10k rpms pretty much forever without a problem. In fact, wankel engines are quite happy to rev at a constant high rpm. That and their low weight is why they are often used in airplanes.
Old Oct 24, 2005 | 01:19 PM
Nemesis8's Avatar
Bigus Rotus
Originally Posted by Dragonrider
...The only thing that is high revving is the crankshaft.
except there is no crankshaft in a rotary
Old Oct 24, 2005 | 02:40 PM
Krankor's Avatar
Klingon Grammarian
Well then what is the proper term for the shaft thingy?
Old Oct 24, 2005 | 02:41 PM
KYLiquid's Avatar
Oil Injection
I have to watch the tach all the time cause when I have the radio up and I am cruising with a good song on, Ill look down and be turing 7500rpm....it sneaks up on you...its so quiet and smooth.
This car at redline feels like my miata at about 4k rpm.....I dont get any vibration, and the sound is pure heaven.
I live at 9500rpm!!!
Old Oct 24, 2005 | 02:43 PM
truemagellen's Avatar
Attracts tree branches
redline?
what redline?
the only thing that stops my fun is that damn fuel cutoff...a realy paint in my side that thing is
Old Oct 24, 2005 | 02:48 PM
legokcen's Avatar
The Turkish Delight
All the vibration!?!?!?!?! The rotary gets smoother as the engine rpm increases. Where are getting vibration from? It shouldn't be from the engine. There is more vibration at idle than there is at higher rpms. The engines are tested to higher limits than 9K.
Old Oct 24, 2005 | 03:11 PM
Of the Black Dragon
Question I'm with Krankor
What do you call the crankshaft in a rotary if not a crankshaft?
Old Oct 24, 2005 | 03:15 PM
Asmoran's Avatar
an eccentric shaft
Old Oct 24, 2005 | 03:16 PM
alcimedes's Avatar
The burninator
e-shaft or eccentric shaft iirc.
edit: damn, foiled by a faster typer.
Old Oct 24, 2005 | 03:22 PM
Of the Black Dragon
Thumbs up Oh, ok then
Originally Posted by Asmoran
an eccentric shaft
The RPM of the eccentric shaft is three time that of the Rotors. There is that better?
Old Oct 24, 2005 | 03:53 PM
shakRpahX8's Avatar
Unknown
I redline on regular basis
at least once everyday
What's the fun in not redlining our Renesis
Old Oct 24, 2005 | 03:54 PM
therm8's Avatar
Bummed, but bring on OU!
Originally Posted by djseto
someone explain how the rotors are only 1/3 of the RPM speed. Is it because the RPM refers to the shaft and that one revolution of the shaft requires 3 revolutions for the intake/combustion/compression strokes? I'm a little fuzzy here...
http://www.rotaryengineillustrated.c...tions/RE3a.php
Old Oct 24, 2005 | 04:08 PM
Ness's Avatar
I think the S2000 is way scarier from 6000 rpm and up than the RX8, but by no means is it a bad thing. I love hearing both the rotary and the F20C at 6k+ rpm. While the Renesis is much more smooth, the F20C SCREAMS was vtec kicks in, pulling much harder. Having driven both cars, anything with that doesn't go up to 9k rpm just seems too little!
Old Oct 24, 2005 | 04:16 PM
RexApex's Avatar
Evil Genius
Ther is one ignition from each rotor for every e-shaft revolution. There are 3 faces to the rotor, therefore three iginitions for each rotor revolution.
--R.
