New '05. I Haven't Had To Add Oil in 1st 1,000 Miles. Huh?
Old Oct 22, 2005 | 10:02 AM
RotoRocket's Avatar
Freely Radical
So, after religiously checking the oil level after every other tank of fuel during the first 1,000 miles, the warm engine is still registering an oil dipstick reading of full.
This is more than a little surprising to me, as I had expected to see at least some oil consumption.
Is this likely to change?
How often is everyone else here finding themselves having to add oil to their (all flash updated) engine?
Old Oct 22, 2005 | 10:10 AM
beachdog's Avatar
Was it overfilled to start with? Most leave the dealerships substantially overfilled when new and after oil changes.
TRZ750's Avatar
Oil usage depends on how hard you are driving. So if you are being carefull during the breaking time the oil usage will be low. If you are driving hard, then you should see some usage by 1000 miles. I have 19K on my 8 and add a qt. every 2500 to 3000 miles (only once between changes). Your oil level was probably a little over full (no problem with the rotary) or some slight changes in level or drain back time, so you don't notice that you have actually used some oil.
Old Oct 22, 2005 | 10:42 AM
REL_RX8's Avatar
2005 RX-8 GT Sunlight Slv
Correct me if I'm wrong... but do you need to get an oil change? (Draining the current oil) Or do you just keep adding oil to it as it burns off? Thanks.
Old Oct 22, 2005 | 10:53 AM
Nemesis8's Avatar
Bigus Rotus
Yes, if you want to maintain your warranty.
Old Oct 22, 2005 | 12:45 PM
I hope you're kidding If you're not...get out your service manual and read it quick.............and find a good dealership that you trust...and have them maintain your car!
Old Oct 22, 2005 | 01:33 PM
RotoRocket's Avatar
Freely Radical
Maybe it was overfilled by the dealership to start. BUT, I checked the dipstick about two days after delivery, and it was just below the full line, and hasn't moved much since.
Old Oct 22, 2005 | 01:36 PM
TRZ750's Avatar
Did you read your owner's Manual? Or are you asking a technical question?
Technically oil needs to be changed for two reasons. One is contaminates build up in time in the oil. The oil filter removes some, but not all. Especially the acids and other chemicles primarily caused by blow by gas. The rotary does not have traditional blow by gas so this is not a major concern. (GM was actually considering a common oil system between the rotary enging and auto trans when they were working on the rotary.) The second reason is the heat and pounding applied to the oil tends to break up the long string molecules is oil, especially the additive packages. The breakup of some is actually good as they found out in WWII when much crankcase oil was just cleaned and reused. But there are many additives, like rust inhibitures that can be damaged. Now days oils have MANY additives and I am not a oil engineer so do not know the full affects. This second reason is probably a good reason to change your oil in your RX8. I never did on my older REPU or RX7s (with no problems), but do on my RX8 every 5K.
Old Oct 22, 2005 | 01:52 PM
RotoRocket's Avatar
Freely Radical
Not only should you change it, but IMHO, you should change it and the oil filter more frequently than what the owner's manual states is acceptable.
I change mine every 3k miles. Whether that's overkill is immaterial to me. I'd rather be safe than sorry.
Old Oct 22, 2005 | 02:01 PM
^^ My thoughts exactly
A good saying I learned from my father when I first started to work on cars when I was a kid.......
" Oil is Cheap...Engines are not "
Has worked for me for over 25 years
I change the oil in my 8 every 3K too....even with Synth
Old Oct 22, 2005 | 02:31 PM
REL_RX8's Avatar
Thanks.
I've haven't even had my 8 for 24 hours yet. I'm going to read the manual now.
Old Oct 22, 2005 | 02:45 PM
Digital_Damage's Avatar
huh? you are putting in Synth?
Old Oct 22, 2005 | 03:23 PM
Rp 5-20
Dokuji
Nov 1, 2016 02:51 PM
Junirol
Sep 22, 2015 06:02 AM
dbarber
Jul 25, 2015 01:34 PM
kaboshe
Jul 17, 2015 03:14 PM
