Question about 4.777 final gear...
Old Oct 20, 2005 | 10:53 PM
RX-8_PENNZOIL's Avatar
Where is the speed sensor place??? on gearbox or on the rear wheels?? coz i want change my final gear from 4.444 to 4.777 ....
i am afriad that if i change 4.777 final gear ... and the speed detector is on the gearbox... so the the speed reading will be wrong ( eg. actual speed is 90km/h will be read 100km/h ) is it have this problem??? and is there any method to solve it???
i just can find " Fujita Engineering (FEED) " have RX-8 final gear set .... is there any other factories have the same product provide???
ps. sorry for my poor English..... hope you guys can understanding what i said~~!!
Old Oct 20, 2005 | 11:07 PM
Yes we understand. I don't know but Rotary God or someone will help you.
Old Oct 21, 2005 | 09:47 AM
KYLiquid's Avatar
Oil Injection
The speed sensor is in the gear box, so chaning wheel/tire size or the final drive WILL make your speedometer read incorectly. not by a whole lot, but it wont be as close as it is not.
As long as you know how much the differnce is its not that big a deal, IMO.
Old Oct 22, 2005 | 12:18 AM
it will indicate 75 mph when you are actually going 70 mph, assuming the stock tire diameter is used
Old Oct 22, 2005 | 12:56 AM
Rotary Rasp's Avatar
503wtq Boosted Bimmer
I think it would cost more to fix then it is worth.
Old Oct 22, 2005 | 03:58 AM
I wants to change my final gear so much because my country is very small and many cars on the roads....
roads are very narrow , and i always run my 8 with other cars ( eg. DC5 , EP3 , Cilo ..... etc. )on the hill roads.... the speed about 85km/h ~ 135km/h , so i uses 3rd gear to run..... but you guys knows, 85km/h ~ 95km/h in 3rd gear ( about 4600rpm - 6000rpm ) RX-8 low torgue is very bad.... so i want keep the engine REV. in 6000rpm - 9000rpm ( rx-8 powerband ) ....... then i think change the orginal final gear to 4.7 or 5.1 is more better my 8..
Old Oct 22, 2005 | 12:18 PM
KYLiquid's Avatar
Oil Injection
the 4.777 gear with lighter wheels than stock and a light flywheel will give a good boost in pickup. and also (as you said) keep you in the power band.
watch out though about the posts of 'running other cars' ... some people might jump on you about racing
Old Oct 23, 2005 | 09:40 AM
if you say ppl may jump on me about racing........ i think not ........... coz i live in Macau....... ppl in RX8club i think no other Macau ppl ......... except me.... hehe
In Macau , just have 9 of RX-8 in Macau .... hard to find ppl to exchange tuning experience........ and i dont like ppl say RX-8 can not being fast in Macau........
Old Oct 23, 2005 | 03:50 PM
oi812's Avatar
RX-8 PENNZOIL check out
http://www.downeyoff-road.com/Engine...edSensors.html
Look at the frequency module neer the bottom of the page. You would neet to REDUCE the frequency by 7% to keep the speedometer accurate for the 4.777 rear axle ratio. Most people who use this for 4x4 trucks need to bump up the frequency to accomidate the large diameter tires so I would ask the manufacturer before you buy.
Macau sounds like an interesting place, I have a friend who raced a motorcycle on a street course in Macau and has scrape marks on his helmet from the guard rails on the inside of the turns.
Sakebomb Garage
Sakebomb Garage
Oct 22, 2015 04:28 PM
DVerdeyen
Sep 13, 2015 11:19 AM
Sakebomb Garage
Group Buy Center
Sep 12, 2015 08:18 PM
yankeepicker
Sep 11, 2015 05:42 PM
LMURailsplitter02
Sep 6, 2015 10:56 PM
