Wheel Spacers - Are they really safe?
Old Oct 20, 2005 | 09:11 PM
Drifter's Avatar
Hi,
Just wanna check with you guys, are wheel spacers safe? If yes, how is the MAX. mm it can go?
PS: Wheel spacers are meant to make the position of the wheels wider apart.
Cheers !!!!!!!
Old Oct 20, 2005 | 10:51 PM
EZZY's Avatar
cry me a river...
no its not safe unless it is welded to the actual hub, so it will not come loose. then again, it is most likely a defect item anyway, check with your local authority first.
its better to replace the stud to a longer one, so you still maintain the whole length
Old Oct 20, 2005 | 11:52 PM
UG_8's Avatar
Well for spacers, it needs to be hub centric type. But again, if you track, don't put spacers...as it will stress your suspension joints.
I had spacers in my previous ride, very stable but the ride quality degrades a bit.
Old Oct 23, 2005 | 09:06 PM
Drifter's Avatar
Wheel spacers
Wow ,
In that case I had better not put spacers in my car. The shop seller said "If a Evo can fit the spacers, I don't see a less powerful and slower RX8 should be a problem."
That does not sound good to me as both cars are different.
Cheers
92trbolzr
May 18, 2025 09:04 AM
snowrydr01
Nov 23, 2015 09:40 AM
Evan Gray
Sep 26, 2015 12:30 PM
