Torque specs for rear suspension
Old Oct 5, 2005 | 02:31 PM
apotocki's Avatar
Does anyone have or know where I can get the torque specs for the entire rear suspension system?
There is information in the lowering springs DIY but it does not contain the specs for things like the control arms and such.
Old Oct 5, 2005 | 03:08 PM
Dark8's Avatar
Ride Naked!
Here you go:
Old Oct 5, 2005 | 03:26 PM
apotocki's Avatar
THANK YOU....wow....lots of parts and hard to follow!
Old Oct 5, 2005 | 03:52 PM
apotocki's Avatar
Let me make sure I understand these figures.
For the rear sway bar u-brackets where it bolts onto the car, is the torque spec (in foot lbs) between 17.6 - 26.5????? They give you a range?
Old Oct 10, 2005 | 10:56 AM
Dark8's Avatar
Ride Naked!
Yes, it's kind of silly that they give you a range. But make sure you look at the correct numbers. In the bottom right hand corner there is a key like N-m(Kgf-m, ft-lbf). The ft/lbs for the bracket bolt would be 13.0-19.5 in the 17.6-26.5(1.80-2.70,13.0-19.5). Hope this helps.
Old Oct 10, 2005 | 11:06 AM
bgreene's Avatar
Time of your life, kid...
It's pretty standard for torque callouts to be given in a range, as there is some uncertainty in most tools (along with their operators). Just set your torque wrench for about the middle of the range given and you'll be fine.
Old Jun 9, 2007 | 10:05 PM
CRX Millennium's Avatar
AA = Autox Anonymous
Well, I finally did the unthinkable and broke one of my rear sway bar bracket bolt. The 12mm nut took the exposed (RWD-facing) bolt by shearing it clean. 99940-0801 is the nut that threads onto the bolt, which seems to be soldered onto the bracket. The backside of the bolt is rounded and flat. There is no part # for the bolt in question, as far as I can tell!
Should I try drilling and back out the bolt from the backside of the bracket (if not soldered), or just have one nut securing the bracket on the rear passenger side? Haven't tried hammering the remaining bolt out for the fear of chewing up the thread.
Old Jun 11, 2007 | 02:53 AM
sorry man, you've got some work to do
https://www.rx8club.com/series-i-do-yourself-forum-73/diy-racing-beat-sway-bar-install-43677/
Old Jun 11, 2007 | 09:02 AM
devildog1679's Avatar
My dealer put in a new bolt for $35 when I broke mine.
Old Jun 11, 2007 | 10:54 AM
Thanks for digging up the link reference, baggy.
$35 seems ok as the last resort. I'll try what I can first myself.
Old Jun 11, 2007 | 06:49 PM
If you have a drill then it should be no problem doing it yourself. Just drill it out and insert a new bolt. The only problem is that with out a lift it may a little awkward. Good Luck
Kahl
NE For Sale/Wanted
21
Aug 5, 2017 02:49 AM
Sakebomb Garage
Sakebomb Garage
Oct 22, 2015 04:28 PM
nowakm99
Oct 9, 2015 07:10 AM
Sakebomb Garage
Group Buy Center
Sep 12, 2015 08:18 PM
