gear changing
Old Oct 5, 2005 | 12:46 AM
inspiron 2650's Avatar
gear changing
does anyone have any experience rattling sort of sound every time you shift gear with a MT? i only have 450 miles in my RX8 and i dunno if the pronounce sound i hear when i change gears is normal when the car is new. the gear change is just very subtle to hear in the inside.
Old Oct 5, 2005 | 12:23 PM
tuj's Avatar
tuj
Go to the dealer and drive another one. That should give you an indication.
Old Oct 5, 2005 | 12:33 PM
smrx8's Avatar
yeah have it checked ASAP
Old Oct 5, 2005 | 12:41 PM
Luftwaffle's Avatar
I get a "kerchak" sound when I shift sometimes.
Old Oct 5, 2005 | 08:37 PM
all right then. i will do that this weekend (07 oct 05). i will go to the dealer and drive a new one
Old Oct 6, 2005 | 12:41 AM
Gerael's Avatar
Rexella's Daddy
i get that sometimes too... Not sure if it just needs to be broken in though.. mines still ~700 miles..
One thing I do know is that when accelerating or decelerating... the gas in the tank moves and makes thunking noises... to better imagine this.. try filling a gallon milk bottle half way with water... and moving it back and forth slowly.. you'll hear that thunking noise too...
Old Oct 6, 2005 | 08:41 PM
yah? i have not heard any of that thunking noises with mine though. it is just when i change the gears, sometimes i could here the gear clunk. are you gonna take your car back to the dealer, gerael?
Old Oct 6, 2005 | 08:44 PM
juikster's Avatar
Im 8 drifting on a budget
I changed the gear oil to Royal Purple brand and shifting is fine...
Old Oct 12, 2005 | 01:11 AM
now i have heard that thunking noise you were talking about. it was when i filled up my tank (full) and everytime i stopped hard, the petrol was shifting inside the tank.
thanks about that royal purple brand. i will try to have one of that.
Old Oct 12, 2005 | 02:52 AM
KuzuRyuuSen's Avatar
i got the samething too, i wanted to make this kind of thread today. it happened to me from 1st gear to 2nd gear, when the engine temperature is still low. then it goes away as the temperature rises. it goes much smoothly when i rev at higher rpm before i change the gear. did you guys have the same thing? i am going to make an appointment for car service tomorrow and have it checked, if it's normal i don't think that's necessary since i'm pretty busy this week.
Old Oct 12, 2005 | 04:00 AM
Gerael's Avatar
Rexella's Daddy
I'm gonna change tranny fluid to synthetic... maybe royal purple...
see if that helps it.. and i believe the tranny works a lot better at higher rpms...
not gonna worry about taking it to dealer unless it gets worse...
do you guys get a sort of metal grindy noise.. very faint.. when accelerating around 1-4k rpm?
Old Oct 12, 2005 | 11:47 PM
all of you have got exactly what i am experiencing with my RX8. if i started from 1st to 2nd gear and shift at around 3krpm, a grinding sound can be heard and a clunk sound of the gear was pronounce. is seemed to be like a loose metal plate or something (not really that bad though). i tried experimenting by reving up the engined on 1st gear at up to 4krpm during start up, gear change was a bit smoother (also when the engine was well warmed-up). but the problem during high temperature is that my cluch sounds like a rubber rubbing together. i dont know about this yet but i will just wait until it gets worse or goes away. i am only on my 9hundred miles with my rx so maybe it's just breaking in.
Old Oct 12, 2005 | 11:56 PM
capncrunch's Avatar
Yep I too have an odd ka-chunk noise which can be heard with gear changes at low rpms from 1st to 2nd (mostly when the engine is still cold). I'm coming up for 9000kms so it's well broken in.
**edit - and i'll be taking it for the dealer to look at with my 10000k service. It just doesn't seem right.
Old Oct 13, 2005 | 12:10 AM
i should be mindful with mine about this one then. please do tell me about the result with your dealer visit and what they've said about it.
Old Oct 13, 2005 | 10:07 AM
cas2themoe's Avatar
PoloRican Rotary
I get that only when the trans is cold. Once it warms up I hear nothing.
Old Oct 17, 2005 | 12:40 AM
about this Royal Purple Transmission Fluid, is there any specific Number that i need to take note when buying one (you know, like 5W-20 for my engine oil). I think i need to change my transmission fluid to help me have a smoother gear-shifting.
thanks.
WranglerFan
May 31, 2022 07:51 AM
JimmyBlack
273
Feb 10, 2020 10:23 PM
WranglerFan
Nov 5, 2017 09:35 AM
nowakm99
Oct 9, 2015 07:10 AM
titaneum_grey
Sep 6, 2015 10:21 PM
