alignment spec, please help
Old Sep 30, 2005 | 01:45 AM
Winning 8's Avatar
Hot Pit
what is a good alignment spec for a stock set up with RB sway bar.
Going to sears point in october.
Old Sep 30, 2005 | 10:04 AM
PUR NRG's Avatar
Did you try doing a search?
________
ANIME WEIRD
Old Sep 30, 2005 | 10:59 AM
Section 8's Avatar
Have you ever been on track before? I'd suggest using the stock alignment specs if you haven't until you learn how the car acts on track.
Old Sep 30, 2005 | 07:04 PM
Winning 8's Avatar
Hot Pit
I did do a few HPDE with NASA, but this been a few year since. Also I drove a CR-X before, so the spec is no use. I did a search but it is japanese spec, they put 550lb spring in front and 480lb in the back, also front is 0 camber, rear is 2 degree. toe is 0 all the way.
I just don't understand how can they drive the car around with those spec.
thanks for the help
Old Oct 1, 2005 | 03:04 PM
Section 8's Avatar
thanks for the help
Hmmm, i guess a good starting point would be some toe in at the front to help straightline stability, and maybe a bit of toe in the rear to help straighten out at corner exit.
The 0 camber is really strange, i'd want at least -1 in front as a starting point, and as much castor as you can get.
Good luck
Old Oct 2, 2005 | 12:54 PM
olddragger's Avatar
hey dude,
Go to a performance alignment shop. The factory specs are all over the place. I have a -1.4 up front and a -1.8 in the rear. I have the same suspension as you. It was like driving a new car man. Awesome turn in. Much better on the track. Does make you pay attention a little more with everyday driving.
Have fun
oh yea the stock castor is good enought for the large majority.
olddragger
Old Oct 3, 2005 | 07:55 AM
tuj's Avatar
tuj
front camber: as much as possible
front caster: as much as possible after camber
rear camber: 0.5 more negative than front, or equal to front
toe: 0 front and rear
Old Oct 3, 2005 | 03:01 PM
Winning 8's Avatar
Hot Pit
Thank you all for the input, I am going to try it out and see the different.
Old Oct 3, 2005 | 06:48 PM
L8APEX's Avatar
Smooth Criminal
I am now at -1 up front, and -1.8 in the rear. It definately drives different now. Much more crisp, stable, and it just feels more planted. It was almost 0 camber before the alignment was done. Toe is set to .05 front, and .07 rear.
gwailo
May 14, 2024 06:57 AM
Quiggs321
Sep 30, 2015 05:34 PM
1.3_LittersOfFurry
Sep 22, 2015 01:54 AM
djp6783
Sep 19, 2015 12:12 PM
