Normal for heating/ac controls not to work with head unit removed?
Old Sep 26, 2005 | 01:03 PM
Coqui's Avatar
Hi all:
I finally got around to pull out the head unit for doing a firmware upgrade/pie adapter job. After pulling out the head unit and putting the rest back together, diligently connecting the 2 adapters for the climate control (I need my car while the head-unit travels around CA), I realized that I can still control the fan speed, but heating doesn't work, nor is any of the leds on the a/c piece in the middle lit.
Is this normal state of affairs with the head unit removed?
It's not like I need the heating nor the a/c, but I'm just wondering if I accidently messed up something or not. I expected the display at the top to go blank, but I thought the climate system would still work.
Any insight is very much appreciated.
Old Sep 26, 2005 | 01:28 PM
forbidden's Avatar
This is normal as the circuitry that controls the climate controls is located inside of the factory radio.
Old Sep 26, 2005 | 06:19 PM
Rotary Rasp's Avatar
503wtq Boosted Bimmer
The search button is your friend.
Old Sep 26, 2005 | 06:37 PM
lurch519's Avatar
www.evoperform.com
https://www.rx8club.com/showpost.php...20&postcount=3
Old Sep 26, 2005 | 06:38 PM
Kel Rx8's Avatar
if your not 1st your last
dont be like that, alot of rx8 owners never believe me when I tell them
Old Sep 27, 2005 | 08:17 AM
ayrton012's Avatar
Ayrton Senna Forever
That's working on that position how it was before you pulled out it. I found an Rx-8 audio rebuilding(below the photo), and they said it was a very difficult work to replace the head unit with working display and climate control. I tried it: I only left the inside of the head unit in the car with longered wires in an other position to leave enough space for the new head unit. It was working about for a week , and after it went wrong. I think the higher resistance of the longer wires made the fault. I took my head unit under the centre console at the end.
Attached Thumbnails Normal for heating/ac controls not to work with head unit removed?-rx8-2.jpg
Old Sep 27, 2005 | 10:18 AM
truemagellen's Avatar
Attracts tree branches
that looks hot!
did u purchase that center console piece or was is a custom job?
if it was custom can they be reproduced easily?
-J
Old Sep 27, 2005 | 12:33 PM
Coqui's Avatar
Very cute remark regarding search, but after going through what I believed to be most threads on head unit removal - remarkably found by doing a search - I felt compelled to post the question. Thanks for the answer forbidden...
escapedan
RX-8 Racing
58
Feb 10, 2020 06:11 PM
Crazy.8
Apr 18, 2017 03:17 PM
arjunmshah
Aug 6, 2015 10:56 AM
MolecularConcept
Aug 1, 2015 03:15 PM
ion_four
Jul 30, 2015 09:48 PM
