View Full Version : Brake Light Keeps Coming on
urby1970
09-17-2005, 09:04 PM
I periodically get a brake light comes on for no reason, it's like I have my emergency brake on light. Then driving down the interstate it will all of the sudden go off, then later it will come on again. Anyone experienced this?????
abbid
09-17-2005, 09:29 PM
Ive noticed when a passenger bumps mine it comes on and i have to lower it sometimes. Other times, they just touch it momentarily and it will cause it to go up. If this is happening when youre solo - you may wanna get that checked.
dannobre
09-17-2005, 09:34 PM
Check the Master cylinder fluid level...probably a bit low. You might want to check your brake pads ...esp the front pads for wear......
urby1970
09-17-2005, 09:49 PM
Thanks I will check it out. If I can't find the immediate problem, I will take it in. I need to take it in for the recall anyway. Thanks!
Shifty Devil
09-18-2005, 01:29 AM
Think this is related to that sticking/stiff brake handle boot problem others have noticed (even though that is usually a winter problem)?
fastlane425
11-03-2010, 09:48 AM
ive been having the same problem and i was just wondering if you ever got it fixed.
lilring
11-03-2010, 12:02 PM
i had the same problem, but all it is, is that the pads are low which causing the brake fluid to be low and set the sensor off. So get new brake pads
