OEM fogs on MS Kit
Old Sep 15, 2005 | 07:24 PM
ToguePirate787's Avatar
Rotary 4 Life
OEM fogs on MS Kit
Hey everyone, I thought I would post this up. I finally got around to installing the OEM fog lights onto my MS kit. I was rather lengthy in my opinion, i guess thats because i didnt have the right tools when i first started. I then decided to go and buy a Dremel to help me out haha, that seemed to speed things up 10x faster. Anyways hope that you guys enjoy the pictures. Oh, I know my car is dirty, so don't flame me too much about that. :p
P.S. I used the Electric Dremel to cut and modify the OEM housings to make it fit the MS kit.
Old Sep 15, 2005 | 07:50 PM
Outlaws eXtreme's Avatar
2010 Prius - Miss the 8
You didn't want to use the brackets? They make the lights point forward... not to the sides. (Look at the top pic.)
At least you saved about 70 bucks doing this.
Oh and I notice it's the replica kit, that's why it didn't have the grill. If it had the MS Grill in front, you wouldn't be able to put the fogs the way you did.
Old Sep 15, 2005 | 08:06 PM
Rotary 4 Life
Yeah it is a MS replica, however the fog light do point forward. I know they may look like the point outwards, but they really don't. They are even with the headlights. Oh, and the brackets wouldn't work on this front bumper, I had to basically make my own for this.
Old Sep 15, 2005 | 10:14 PM
kw1k's Avatar
Whats the main differnce between the replica and the jdm one?
Other then the grill?
Old Sep 16, 2005 | 01:33 AM
The Grill, Saves money, and the material is slightly different. That's about it.
Old Sep 18, 2005 | 02:35 PM
kwescott's Avatar
One ball, corner pocket
and don't forget the portion that covers the rebar. The JDM version has a curved piece of black plastic where as the replicas leave that space open so you get to stare at the unpainted bumper rebar below.
And given the difficulty he had in installing his OEM foglights, I would assume that the back portion of the replica is different from the JDM. The JDM required trimming of the mesh grills, as well as drilling two holes in the backside of the bumper to attach the new foglight brackets.
As for the material...most replicas are urethane, which means that they are more flexible than the JDM version.
Old Sep 18, 2005 | 02:38 PM
kwescott's Avatar
Do you mean that you tried to use your brackets from your original bumper, or do you mean that you purchased the MS foglight brackets (which are significantly larger than the stock brackets) and attempted to make them fit. I find it hard to beleive that you wouldn't be able to attach the MS foglight brackets.
Old Sep 18, 2005 | 03:37 PM
Anthony's Avatar
I am not sure but i think you are fitting them to low, mine were done by the dealership when i bought the car, i have attached a couple of pics
If you want me to do a couple of closer pics let me know
Anthony
Old Sep 18, 2005 | 10:29 PM
kwescott's Avatar
yup, thats where they should fit....
Old Sep 22, 2009 | 09:31 PM
Youwonder's Avatar
5 Boro Rotary......5BR
so what did you do pics step by step???
JimmyBlack
273
Feb 10, 2020 10:23 PM
RXFEVER
Aug 29, 2018 10:14 AM
RXFEVER
Sep 11, 2016 02:51 PM
wayloco
Sep 1, 2015 09:03 PM
