Replaced Greddy turbo hoses/reducers/clamps
Old Sep 10, 2005 | 05:50 PM
adrian-1's Avatar
Ex- member.
I plan to up the boost soon and I decided to checkout the condition of my reducers/hoses. About half of them were cracking although none had cracked all the way through yet.
I replaced all the blue hoses and reducers that connected the piping for the Greddy turbo kit. I purchased the new ones from http://www.hightempsilicone.com/ , the total bill was around $150.
I've only had my kit 7 months and there was noticeable wear/tear on the reducers/hoses. The worm clamps bit into the silicone and there were cracks on a few, even on the inside. The new clamps I used are T-clamps and do not bite into the silicone like worm clamps.
Attached Thumbnails Replaced Greddy turbo hoses/reducers/clamps-img_2617jpeg.jpg   Replaced Greddy turbo hoses/reducers/clamps-img_2621.jpg   Replaced Greddy turbo hoses/reducers/clamps-img_2624.jpg   Replaced Greddy turbo hoses/reducers/clamps-img_2628.jpg   Replaced Greddy turbo hoses/reducers/clamps-img_2630.jpg
Old Sep 10, 2005 | 05:52 PM
adrian-1's Avatar
Ex- member.
more pics
Attached Thumbnails Replaced Greddy turbo hoses/reducers/clamps-img_2632jpeg.jpg   Replaced Greddy turbo hoses/reducers/clamps-img_2644.jpg   Replaced Greddy turbo hoses/reducers/clamps-img_2647.jpg   Replaced Greddy turbo hoses/reducers/clamps-img_2648.jpg   Replaced Greddy turbo hoses/reducers/clamps-img_2650jpeg.jpg
Old Sep 10, 2005 | 06:09 PM
MadDog's Avatar
Consiglieri
Looks nice! Can you post the shopping list? I guess you had to buy them separately.
-MD
Old Sep 10, 2005 | 06:53 PM
Moostafa29's Avatar
Storm Trooper
Yeah, looks great!
Old Sep 10, 2005 | 07:42 PM
adrian-1's Avatar
Ex- member.
I'll get the shopping list together and post.
The reducer on the pipe going down from the throttle body was alittle too big. I believe they were out of the correct size on all colors (2.5 to 3). I got 2.75 to 3 and made it work.
Old Sep 11, 2005 | 12:39 PM
PUR NRG's Avatar
Interesting find. Did you contact Benny to get his opinion?
I wasn't impressed with the kit hoses to begin with and used silicone ones from HoseTechniques instead. Nice to know I made the right choice.
________
Free themes
Old Sep 11, 2005 | 06:05 PM
adrian-1's Avatar
Ex- member.
No, I didn't talk to Benny.
I read a thread where the puerto rico member's reducer split open when he increased the boost (10psi?). So I decided to check mine out.
Old Sep 11, 2005 | 06:16 PM
drifter_d's Avatar
Registered Drifter
good info, adrian-1. look forward to seeing the shopping list when you get the chance. thanks.
dd sends...
Old Sep 11, 2005 | 06:21 PM
RX8PR's Avatar
Adrian,
you're new hoses looks great..................................
the reducers that came with the greddy kit are not top notch.
Manuel
Attached Thumbnails Replaced Greddy turbo hoses/reducers/clamps-img_0540.jpg   Replaced Greddy turbo hoses/reducers/clamps-img_0542.jpg
Old Sep 11, 2005 | 09:42 PM
adrian-1's Avatar
Ex- member.
Diagram of couplers/reducers below. The numbers in parenthesis would fit better than the ones I got.
If you want to replace the 3 hoses on the air intake , you'll have to measure those yourself. I didn't replace those since they're not pressurized. Also, I relocated my filter behind the bumper using the websites intercooler 12" hose.
Attached Thumbnails Replaced Greddy turbo hoses/reducers/clamps-hoses.jpg   Replaced Greddy turbo hoses/reducers/clamps-hoses-list.jpg   Replaced Greddy turbo hoses/reducers/clamps-img_2640jpeg.jpg
Old Sep 12, 2005 | 10:34 AM
PUR NRG's Avatar
How did you clamp the intercooler hose to the intake filter? And is that a 3" or 3.25" ID?
________
Depakote attorneys
Old Sep 12, 2005 | 04:09 PM
adrian-1's Avatar
Ex- member.
The intercooler piping is 3" ID and 12" long (I had to trim 1 inch off).
To connect the two, I used a 3" (76mm) hose joiner found here.
Old Aug 19, 2006 | 01:17 PM
mysql101's Avatar
This is a highly recommended mod for the stock greddy kit.
Mine also burst: http://proxy.searchirc.com/turbo/brokencoupler2.jpg
I tried to order from HTS, but they are out of transition hoses. I ended up going with MazworxRaceSupply.com (Located in Orlando).
Plus all the t-clamps came up to a total of $130 including shipping.
Edit: I replaced all hoses and all clamps, including clamps on the intake. So I spent around 200.
Old Dec 25, 2006 | 11:16 PM
LiL BenNy's Avatar
Bubblicious? DEF.
are the clamps needed or....?
Old Dec 26, 2006 | 07:17 AM
mysql101's Avatar
the t-bolts are better. mostly because they don't eat into the couplers (see pics above)
Old Dec 27, 2006 | 10:15 PM
Slick8's Avatar
Here's a pull from the Greddy Turbo Manual with the dimensions converted from Metric to English
33. Rubber Hose 50D x 70mm – 2 --> 2”D x 2-3/4” – 2
34. " 60D x 70mm – 3 --> 2-3/8”D x 2-3/4” – 3
35. " 80D x 60mm – 1 --> 3”D x 2-3/8” – 1
36. Silicone Hose 50D – 60D Reducer – 1 --> 2”D - 2-3/8”D – 1
37. “ 80D x 80D Reducer – 1 --> 3”D x 3”D – 1
38. “ 80D – 90D Reducer – 1 --> 3”D - 3-1/2”D – 1
39. Hose Band 16D #10 – 2 --> 5/8”D – 2
40. “ 50D #32 – 5 --> 2”D – 5
41. “ 60D #36 – 8 --> 2-3/8”D – 8
42. “ 80D #48 – 4 --> 3”D – 4
43. “ 90D #56 – 1 --> 3-1/2”D – 1
Old Dec 27, 2006 | 10:26 PM
Slick8's Avatar
In case you were wondering... I decided to replace everything including the vacuum hoses and came across this.
Vacuum hose reliabilty test (scientific experiment): Viton vs. Neoprene vs. Silicone (thanks TracyRX7)
http://www.geocities.com/MotorCity/G...5/hosetest.pdf
Old Dec 27, 2006 | 11:19 PM
Viton tubes ... where can I get those ?
Old Dec 28, 2006 | 07:06 AM
mysql101's Avatar
you can get it here:
http://hightempsilicone.com/category/vacuumhoseviton/
They cost about 5x more than silicone hoses...
I wouldn't bother. The vacuum hoses aren't in locations where it gets really hot.
I did buy pure silicone hoses (red), cost me about $50. It looks great.
Old Feb 8, 2007 | 09:51 PM
LiL BenNy's Avatar
Bubblicious? DEF.
anyone who needs coupler..... HTS seems to be out of stock on a few hoses... i googled and found this place.... http://www.extremepsi.com/store/cust...me.php?cat=772
found it a bit cheaper (few cents off most hoses) but there is at 7.50 handling fee, no biggie got everything + 14 clamps for 126
Old Feb 12, 2007 | 11:44 AM
LiL BenNy's Avatar
Bubblicious? DEF.
i just recieve my hoses today from extremepsi, shipping was fast!
hoses look kinda small... from what i last remember the piping was bigger? i hope these are the right sizes... we'll see tomorrow...
Mxttz0r
Jul 5, 2019 03:19 AM
jay_tibo
22
Sep 13, 2016 08:10 PM
RicerX1
Jan 11, 2016 05:59 PM
dancingdan42
Aug 19, 2015 09:29 AM
cschoeps
Aug 6, 2015 12:44 PM
