Discman2
09-09-2005, 05:40 PM
I went to go pick up my little sister from school and the wierest thing happened. The engnie just started sputterening as I came to a stop and I could feel that it was on the verge of shut down(don't know why). after a couple seconds really struggling to move the engine just stalled.
I turned it back on after a few seconds, but I could feel that it was running extremely poor and I could feel the onset of the sputterening again. I decided to drive extremly conservative and keep a few miles under the speed limit :eek: At each light, or stop, when i slowed down I could feel it was on te brink of shutting down s I threw it in neutral and it seemed to calm down, but once I put it back in drive it went to shit if I didn't accelarate enough. A few traffic lights later, as I was coming to a stop, the sputterning came back and the engine stalled again once I completely stopped. I turned the key a few times... nothing.... then finally it started just barely. then stopped. Turned the key again->barely started->shut down...Finally it started(i hit the gas as i turned key, didn't wait to drive off like before)
I pulled into a 711 to call for help. I barely made it into the parking spot. In fact the 711 is in a depressed piece of land, so there is a little hill. I stalled midway through the tiny hill and used momentum to pull into the space :rolleyes:
I called for Mazda Roadside, but then cancelled because I figured the dealership would blame the problem on the RB intake and charge me up the ass to fix the problem. Here's the strange part.... While parked I turned the car on to get some cool A/C(i live in So. Fla., so after 5 minutes I was sweating like a prostitute in church) and the car turned on like normal..... I kept it running for a good 20 minutes before my dad showed up. We decided to risk it and drive home so I could fix it myself(hopefully with you guys' help) On the way home the engine ran pretty good, increasingly better as I drove. :confused:
So anyways, now I'm kinda stumped.... The engine was running perfect all day long. I have a half a tank of regular gas. Oil was ok. Heat readings at normal. I was driving at a conservative rate today. But then this whole mess... And now it SEEMS to be running fine. I even went around the block friskly(high rpms). Still runs good.
ANYONE KNOW WTF JUST HAPPENED TO MY CAR?
My crack pot theories:
I kinda blamed it on the RB intake. I thought maybe it was stuffed up or something was restricting airflow(maybe a piece of paper surrounded itself around the filter???) I'm gonna check it later. Seems like whatever was clogging the airflow got unjammed, because it's running fine....
Or I figured it was a problem with the MAF sensor. Becuase I heard it could malfunction when you get the RB intake
Then I thought it could have to do with the recalled parts(which I am going in for tomorrow)
Sorry for such a long and drawn out post, but I need help!!!
