Calling Hymee and/or SCO - comments on recall ECU change
Old Sep 8, 2005 | 07:59 PM
labrat's Avatar
Forgive me for breaking out of the sticky, but I'd like someone to speculate on the possible effects of the intended re-programming of the ECU to minimize exhaust heat build- up. Specifically, what are the possible effects on (a) performance or (b) fuel consumption as a result of this change? What parameters will this change affect?
Old Sep 8, 2005 | 08:15 PM
Gomez's Avatar
Shifty Bastard.
To the best of everyone's knowledge, there are no parameter changes other than the restrictions on engine speed while stationary or the change in the throttle failsafe mode. Neither of these will affect fuel consumption or performance under normal driving conditions.
Info is only available for the PCM reprogram on North American cars at this time. As Australian RX-8's get different software to American ones, it's all just conjecture at this time anyway. Odds are though, we'll cop the same changes.....whether anything else is changed for the new flash is yet to be seen.
Old Sep 8, 2005 | 09:14 PM
Lock & Load's Avatar
Iwas told that my last re-flash was to rectify the heat build up in the exhaust , but i cannot see any difference in performance or fuel consumption so far :D
B...free
michael
Old Sep 9, 2005 | 01:03 AM
Revolver's Avatar
Shootin' from the hip
Makes sense that they will only control revs at idle judging by everything I've read on this particular recall.
I'm gonna check with my SM anyway just to make sure.
Old Sep 9, 2005 | 02:01 AM
EZZY's Avatar
cry me a river...
B...free
michael
cool, thats good to know, thanks for that.
btw... what happened to your piggyback?
Old Sep 9, 2005 | 02:10 AM
Gomez's Avatar
Shifty Bastard.
No, not the revs at idle......controls the revs while stationary, there is a big difference. After this flash, if you floor the accelerator while stationary, the engine will drop to idle after 10 seconds (regardless of accelerator position). Do 3000-8500rpm and it'll drop to idle after 2 minutes. Do 1300-3000rpm and it'll drop to idle after 5 minutes.
Gomez.
Old Sep 9, 2005 | 02:33 AM
labrat's Avatar
Gomez.
So how does this affect us in day-o-day driving?
Old Sep 9, 2005 | 03:04 AM
rotarenvy's Avatar
Gomez.
your supposed to do 2500rpm for 5min then to 3k rpm and repeat to burp the cooling system.
if this did cause a problem mine would be F*!#ed :D
suppose I'll find out next week.
Old Sep 9, 2005 | 04:33 AM
Gomez's Avatar
Shifty Bastard.
It doesn't.
Old Sep 9, 2005 | 04:37 AM
Gomez's Avatar
Shifty Bastard.
There are other ways to bleed the cooling system.....
COOLING SYSTEM AIR BLEEDING
Applicable Models
Model Starting S/N Ending S/N
2004 RX8 00000000 ZZZZZZZZ
After performing repairs or any time cooling system coolant is drained, the cooling system must be purged of air. Use the following procedure below to remove air from cooling system: 1. Safely elevate front of vehicle on hoist. Elevating the front end only, at a steep angle will allow air trapped in system to escape easily. 2. Temporarily remove a coolant hose to the throttle body. 3. Fill coolant system with proper mix ratio of coolant / water per work shop manual. 4. Start engine N carefully monitor coolant level, topping off as necessary. 5. When coolant begins to flow from throttle body hose, air is bled from system. 6. Carefully attach coolant hose back to throttle body pipe. **Caution, coolant may be extremly hot! 7. Verify proper coolant level N add as necessary. 8. Check system for leaks. 9. Verify repair.
Old Sep 9, 2005 | 06:10 AM
Hymee's Avatar
Race Steward
And Taka reports that his calibration ID did not change during the service, so it would appear it didn't get the reflash.
Cheers,
Hymee.
Old Sep 9, 2005 | 06:11 AM
rotarenvy's Avatar
I don't think the RPM method works anyway. I might give this other one a go this weekend.
Old Sep 9, 2005 | 06:21 AM
Wildcard's Avatar
NT Rotorhead
Gomez,
Do you think I can get my service department to bleed my cooling system at my next service? Is this a procedure they know about? If I know my service department, I would guess.... not.
Old Sep 9, 2005 | 06:25 AM
Gomez's Avatar
Shifty Bastard.
Cheers,
Hymee.
He should've. Where'd he go?
Old Sep 9, 2005 | 06:26 AM
Gomez's Avatar
Shifty Bastard.
Originally Posted by Wildcard
Gomez,
Yep....they should know it. Print it out and take it in if you're that worried about them..... :p
Old Sep 9, 2005 | 06:27 AM
takahashi's Avatar
Cheers,
Hymee.
They did I have no damage to the fuel tank.
I have to see YellowOzRX8's car after recall and repair and see if his car has the new flash.
Is that no damage = no reflash? It does not make sense though
Gomez,
I went to Garry & Warren Smith at Mulgrave - the closest dealer from the MA office.
Old Sep 9, 2005 | 06:32 AM
Gomez's Avatar
Shifty Bastard.
Shoulda gotta reflash mate....even says so on the recall letter. Shoulda stuck with Rita, mate.....
Old Sep 9, 2005 | 06:41 AM
takahashi's Avatar
Hahah I will take it up to them in 2 weeks LOL.
We yet to see the CalID for the reflash and I thought I will be the first one :o
We will meet next weekend right? I will check all of you guy's flash
Old Sep 9, 2005 | 06:42 AM
Gomez's Avatar
Shifty Bastard.
I'll have my new one by then......
Old Sep 13, 2005 | 12:32 AM
Rosso Diablo's Avatar
Hi guys. I was flashed yesterday as part of the recall and replacing my plugs after the great flood of '05.
First impressions are positive. Very smooth and appears more responsive/torquey at low revs. Could of course be the new plugs. I mentioned the starter motor/ battery (nicely) but they didn't seem very interested.
No work done on any of the recalls. Good customer service though from City Mazda Melbourne. By the way if you insist (even more nicely) City will supply a Mazda 2 courtesy car FOC. Usual charge $33 or so they say.
Cheers
PS. I managed to scratch the side fake aluminium panel running along the right side of the centre console side when installing the short shift some time ago. Any ideas on a suitable touch up paint or will I need to change the panel?
Old Sep 18, 2005 | 11:54 PM
Lone Ranger's Avatar
Got my recall done at City Mazda and they say they put heat shielding on but did NOT do any flash.
Old Sep 19, 2005 | 01:05 AM
Gomez's Avatar
Shifty Bastard.
Your car needs one, unless it had one a few weeks ago. Talk to someone there who knows what they're talking about. I had my recall done there last week.....and it got re-flashed.
Old Sep 20, 2005 | 09:48 AM
RXP33D's Avatar
Over time I've noticed the ECU swing less etc. It doesn't idle rough at all even with the intake.
And fuel economy is simply awesome,don't know about you's but compared to the old flash,
this thing works a treat. Don't have to be scared to give it the bootful no more.
Old Sep 20, 2005 | 07:49 PM
dracoMJB's Avatar
Will find out about my recall tonight. Werribee Mazda has given me a Mazda 3 for the day. I was hoping they'd have a new MX-5 I could borrow but I didn't see one or the friendly sales guy to ask. Probably a good thing too as I'd want to buy one I'm sure.
ASH8
20
Sep 26, 2022 11:55 PM
ASH8
Oct 30, 2021 12:50 PM
Audio Concepts ATL
Sep 26, 2021 01:59 PM
