Question about Flashing
Old Aug 25, 2005 | 08:51 PM
rotor_man's Avatar
Hi, I live in NZ and purchased a couple of months ago a slightly used RX-8 imported from Japan. This is the Japanese type S which is similar to the Aus and NZ hi power model which brings me to my question. From what ive read the the Jap model has a tad more power 184kw compared to 177kw, now if i take my car in to my local mazda dealler and get him to re flash my car will i end up with less power? Does the power difference come from the ecu or is it in the cat Any help would be appreciated, by the way i am really satisfied with my car and really enjoy it!
Old Aug 25, 2005 | 09:39 PM
rotarenvy's Avatar
I guess the power is in the tune as a cat will only affect your emmisions not your mixtures. a little more air-flow through a cat isn't going to give you that much more power.
Old Aug 25, 2005 | 10:54 PM
sco's Avatar
sco
The power difference will be due to a different tune. If you get reflashed with a NZ map it is likely you'll have reduced power.
Old Aug 25, 2005 | 11:07 PM
rotor_man's Avatar
i thought as much, so the best thing is not to get reflashed i guess. thanks for your help
Old Aug 25, 2005 | 11:24 PM
Revolver's Avatar
Shootin' from the hip
Most Mazda service centres claim they do it automatically so you'll need to give them a specific instruction NOT to do it.
Good luck and enjoy.
Old Aug 26, 2005 | 02:19 AM
takahashi's Avatar
I wonder what the version of the flash is....
I met someone in Hong Kong who claimed to have a JDM Type S from the HK dealer and the flash is the F flash that we have!
Can you access to a CAN scanner for the Calibration ID code...?
Old Aug 26, 2005 | 06:09 AM
et381's Avatar
Humm.. maybe you are also speed limited to 180km and reflashing with our flash will lift the top speed limit.
Old Aug 31, 2005 | 05:49 PM
rotor_man's Avatar
I guess the only way to find out is take it to Mazda, to get the id code, i have no other access to a can scanner.
i guess it might lift the speed limit but i dont want to sacrafice power for top end which i don't really use be it only a small amount of power but it all counts a!
Old Sep 1, 2005 | 12:24 AM
skc's Avatar
skc
rev it up
You may be better off finding a specialist rotary mechanic to service your vehicle.
skc
Old Sep 1, 2005 | 06:05 AM
takahashi's Avatar
I guess the speed limit is deep down in the PCM and the flash may not touch it. Well are you willing to test it after you flash.
To be honest, dynoing some Japanese Type S yield the same figure as the US spec. So I guess there is not much difference. Anyhow, if no prob, I will advice against a new flash.
Old Sep 1, 2005 | 10:22 PM
rotor_man's Avatar
i think at the moment i will just leave it, why fix it if it aint broken. thanks for your help guys
RevMeHarder
Jun 1, 2026 02:30 PM
JimmyBlack
273
Feb 10, 2020 10:23 PM
DVerdeyen
Sep 13, 2015 11:19 AM
