Is it possible to install REVi without the box?
Old Aug 23, 2005 | 03:30 PM
Discman2's Avatar
Rotary Noob
I ordered REVi and the duct over the weekend and I got into a discussion with someone who saw REVi and commented how the box restricts airflow.
Now, i'm not believeing him, but either way I have 3 questions to the knowledgeable:
1. Does the box restrict airflow?
2. What purpose does the box serve?
3. Could the REVi be installed without the box if I wanted to do it?
i searched and couldn't find anything on it.(maybe I didn't search hard enough)
Besides this, I can't wait to get my REVi and ram duct! Ordered it on mazdaparts and got discounts and free shipping. :D
Old Aug 23, 2005 | 03:38 PM
ZoomZoomH's Avatar
Mulligan User
1. no
2. protection and insulation from the engine bay, as well as being a 'resevoir' for creating a low level 'ram air' effect when driven at high speed with the Ram Air duct installed.
3. no, there are no mounting points on the air filter that allow it to mount to the car, unless you DIY some sort of bracket for it.
Old Aug 23, 2005 | 03:40 PM
Tigster's Avatar
RX8 ADDICTED!!!
If you just wanted the filter and no box why not save a bunch of money and just stick a cone filter on the car? Racing beat spent alot of time and money coming up with the design. I dont know the reason for the box but if they designed the use of it I would say you need it. Plus with the ram air intake it blows the air right into the box instead of just towards the filter.
Old Aug 23, 2005 | 03:56 PM
Discman2's Avatar
Rotary Noob
I wanted the whole deal. I'm just asking.
Old Aug 23, 2005 | 04:36 PM
staticlag's Avatar
The Professor
Without the box, hot air from the engine gets used for combustion. Every 10 degrees up or down is about 1 hp lost/gained, So if its around 115 in the engine bay, you do the math.
But besides that, the box does not restrict airflow.
Stick&Cone filter? K&N Typhoon? If you want one everyones been unloading theirs, im sure you could get one cheap.
Old Aug 23, 2005 | 05:03 PM
rotarygod's Avatar
FWIW: Every intake on the market can flow more air than what the engine needs. This means none of them are a restriction to airflow from the engine's point of view. Some flow more than others do but if even the worst flowing system out there can still flow more than the car needs, even it isn't a restriction. There is far more to an intake than just pure flow. There is tuning. Racing Beat spent alot of time on this. The ram air duct makes things even better when used in conjunction with the REVi intake. Racing Beat found during testing of the unit that at freeway speeds and higher they could actually get positive pressure inside the airbox! You won't see that on a stationary dyno. Whoever said the airbox is a restriction is just guessing. Air is funny stuff. You can't always tell what it does by just looking at where it flows.
Old Aug 23, 2005 | 05:22 PM
Discman2's Avatar
Rotary Noob
I was waiting for rotarygod to explain it.
:D
Old Aug 23, 2005 | 07:04 PM
ZoomZoomH's Avatar
Mulligan User
what, my explanation aint good enough?? :o
Old Aug 23, 2005 | 07:22 PM
rotarygod's Avatar
Longer sentences with bigger words sounds more intelligent!
Old Aug 26, 2005 | 09:10 PM
neit_jnf's Avatar
lol
Old Aug 27, 2005 | 01:18 AM
xy4xx's Avatar
is it possible to get the revi without the ram duct?
Old Aug 27, 2005 | 02:15 AM
truemagellen's Avatar
Attracts tree branches
yes definitely
Old Aug 27, 2005 | 03:03 AM
zoomzoom_8's Avatar
any body seen a mod for the racing beat intake with ram air for a greddy turbo? The airnix intake is a P.O.S. not to mention all that hot engine air.
Old Aug 27, 2005 | 08:49 AM
willhave8's Avatar
Yea, I sometimes save up RG input and then have to schedule time on my calendar to read and ..... understand them. for some, you need to get out your calculator -- But even then, I still don't always understand them.
JimmyBlack
273
Feb 10, 2020 10:23 PM
WranglerFan
Nov 5, 2017 09:35 AM
yurcivicsux
192
Sep 12, 2017 10:54 PM
RenzoRx-8
Sep 9, 2015 02:38 PM
projectr13b
Series I Do It Yourself Forum
Sep 6, 2015 01:04 PM
