Is there a problem with an rx8?
Old Aug 22, 2005 | 02:15 PM
EvritaniaGR's Avatar
hey im not sure but i herd some thing about the rx8?
1st when u drift,loose control, or when u slide on the ice and the car goes back the car turns of and there is a switch were the seat is at so u can turn it back on or something? is that true? explain it to me better if u know what i am saying?
Old Aug 22, 2005 | 02:23 PM
Intrigue 8's Avatar
No u are the weakest link goodbye
Old Aug 22, 2005 | 02:25 PM
KYLiquid's Avatar
Oil Injection
i dont quite understand the question....
your in a slide or loss of traction situation, the car tunes off? is there a switch near the seat that turns it back on?
im not sure, are you talking about the TSC/DCS (traction/stability control)?
Old Aug 22, 2005 | 02:29 PM
MTCD01's Avatar
Maybe you read the 360 thread where the car cut out?
If you drift or slide on ice the car will not die on you. If the car is equipped with DSC then the system will need to be dissabled before you go sliding around intentionally.
Old Aug 22, 2005 | 03:14 PM
Nubo's Avatar
Lubricious
The higher-end models (Sport, Touring and Grand Touring) come with stability control and traction control. If the computer senses that you are sliding, it will activate the brakes individually and also back off the throttle if necessary, to keep you from skidding or spinning. The throttle is only retarded long enough to restore stability. This does not turn off the car.
There is a switch to turn off these systems, if desired. This means you can drive without the traction or stability control if you wish. Once you disable these systems you can't turn them back on without restarting the car.
How's that?
Old Aug 22, 2005 | 03:29 PM
beachdog's Avatar
Minda, is that you?
ladnarf1
Apr 29, 2021 11:53 PM
Skyl3r
Dec 2, 2019 04:51 PM
SIllver
Aug 1, 2015 07:34 PM
Belalnabi
Jul 22, 2015 04:50 PM
Belalnabi
Jul 17, 2015 07:48 PM
