Stock Wideband O2 Sensor - Can it detect the full range of AFR?
Old Aug 22, 2005 | 11:11 AM
brillo's Avatar
Go Texas Longhorns!
There seems to be some disagreement over whether or not the stock wideband can sense below 12? AFR, and I did a seach but didn't see any real discussion of this.
I have monitored the stock sensor with my canscan and seen it go below 12, as did many others who tuned their CZ units with the canscan. Someone had mentioned that there was a software issue with the canscan that caused false readings?
Anyways, I just wanted to clear this up, from what I can tell with using an external wideband, it matches closely with the stock sensor and does go below 12 up high in the rev range at WOT.
Old Aug 22, 2005 | 11:39 AM
KYLiquid's Avatar
Oil Injection
im not sure. My friend has one of the cheapest stand alone widebands for his MS Protege and his will read from 9.99-19.99....
is there a way to get a stand alone system to read the AF?
JimmyBlack
273
Feb 10, 2020 10:23 PM
TotalAutoPerformance
Vendor Classifieds
12
Oct 17, 2018 09:00 AM
yurcivicsux
192
Sep 12, 2017 10:54 PM
projectr13b
RX-8 Racing
20
May 14, 2016 06:25 PM
XianUnix
Sep 29, 2015 03:48 PM
