Limbo Rock! Just a little lower!
Old Aug 16, 2005 | 01:15 PM
Vanquish's Avatar
Hi guys...
Was tinking about lowering my ride for another one inch, any springs that can do that???
Old Aug 16, 2005 | 08:48 PM
coupe07's Avatar
SC 300HP!!
Originally Posted by Vanquish
Hi guys...
u wan the change of the whole coilover? or juz the spring??
if its only for aesthetics purpose with a slight gain on performance, go for juz the change of springs....
if u have a little bit more cash, change the whole coilovers....
Old Aug 16, 2005 | 11:17 PM
Vanquish's Avatar
Nope... broke liao... tink I prefer just change the springs... :P
Wat can u recommend bro? :P
Old Aug 16, 2005 | 11:58 PM
M-ster's Avatar
Check out the Suspension forum. There are quite a few thread discussing just on springs. Tein seems to be fairly popular. (which i think easily obtainable in singapore) the other one is Racing Beat.
Old Aug 17, 2005 | 12:22 AM
Vanquish's Avatar
Thanxs bro!
Old Aug 17, 2005 | 01:13 AM
coupe07's Avatar
SC 300HP!!
again, refer to my signature bro..... three choices!!
Old Aug 17, 2005 | 01:15 PM
Vanquish's Avatar
Can PM the prices? Probably will take the cheapest... me cheapo... :D
Old Aug 17, 2005 | 08:51 PM
M-ster's Avatar
Well dont forget to buffer in another $100-$150 for labour to install the spring and $60 for alignment.
Frankly, me think not worth it by just doing the springs. Why dont you get a set of sways too. That plus the spring will improve the handling quite a bit! With about $200 for labour you can both spring and sways installed.
Old Aug 17, 2005 | 11:20 PM
sqflyer's Avatar
Heavy Machinery Operator
Another thing you gotta be careful about in changing only the springs is it may not match your dampers and eventually cause them to become defective in time to come. If you intend to change your entire suspension with coilovers in future, then this may not be a problem. IMHO, best is still to stick with stock, save the money and put them towards a proper set of coilovers in future. My 2c.
Old Aug 17, 2005 | 11:28 PM
coupe07's Avatar
SC 300HP!!
dun have to worry abt this problem, bro.... the jap products are R&D-ed to fit our stock suspension...... I dunno abt the US though....
Old Aug 18, 2005 | 12:24 AM
sandman369's Avatar
some views to share:
not sure how much R&D one can do to retain the matching. dampers are designed for certain travel and stiffness. by replacing the springs of a shorter travel and increased stiffness, defintely there would be some mismatch, unless the change in stiffness is not far off.
R&D if any, would be focused on the fitting (so that there is no wierd sound and have a good fit to serve its purpose), and on matching, i beileved that the design assumption would be that stock dampers would be replaced (possibly by another damper designed together to match the lowered springs), and not so much on matching the stock damper (which the design space is limited and would not make sense). in my view, it's purely aesthetic to lower car without changing damper. generally, handling will be poorer given this mismatch.
Old Aug 18, 2005 | 01:00 AM
Vanquish's Avatar
Thanxs for all the feedback bro...
I'm a pretty aesthetic person, I dun drive my car too hard, till now, the fastest I went was 130kmH. and dat's like only once!
Question, would changing an entire set of coilovers affect the ride comfort alot... my preference for springs is that I already find the car a little bumpy, especially going over strips... thats the problem when u come from driving a Rav-4... :D
Anyway, if the ride comfort isn't badly affected, I dun mind a coilover set... I just wan the car to be lower by another 1 or 1.5 inch as I tink it would look great! :P
Thanxs!! Any feedback is greatly appreciated! :P
Old Aug 18, 2005 | 01:37 AM
lohsk's Avatar
"Beng Your Ride"
You could go the way of Des453 where a set of 20 inch wheels will fill up the gap and still keep your stock stuff. But you have to ask him how's the comfort level.
Old Aug 18, 2005 | 02:19 AM
Vanquish's Avatar
Poison!!! :D
Old Aug 18, 2005 | 03:00 AM
lohsk's Avatar
"Beng Your Ride"
Poison!!! :D
no... training...
Old Aug 18, 2005 | 04:02 AM
Vanquish's Avatar
no... training...
You're evil!! :D
Old Aug 18, 2005 | 11:22 AM
M-ster's Avatar
130km/h!!!
That's already 40km/h more than the speed limit on the highway!!
You're driving way too fast! You've got to slow down!
Old Aug 18, 2005 | 01:33 PM
Vanquish's Avatar
130km/h!!!
In Malaysia mah... any slower, I'll be road-hogging... :P
Old Aug 18, 2005 | 11:53 PM
des453's Avatar
Wah....u really want to poison him! Anyway is always in the blood of 8 owners! hahahah
the 20 inch rims will not loose much of the comfort anyway! Vanguish, if u change your springs, it might! but really depends on wat springs u have.
Old Aug 19, 2005 | 12:04 AM
linus's Avatar
M@cDreamy
i always tot the aftermarket springs r catered for the 6MT sports suspension
do they work for the 4AT suspensions?
Old Aug 19, 2005 | 12:09 AM
coupe07's Avatar
SC 300HP!!
arent the suspension same across the range of rx8s??
Old Aug 19, 2005 | 12:20 AM
LsBlack's Avatar
vanquish,
wat lohsk suggest is super,
u got the look for 20" while veing the comfort.
steal, rob, beg, just do it. :D
u should look at bro des453's ride
Old Aug 19, 2005 | 12:32 AM
coupe07's Avatar
SC 300HP!!
Originally Posted by LsBlack
vanquish,
look at the video clip by lohsk... u shld be able to see the 20inchers.
Old Aug 19, 2005 | 12:34 AM
linus's Avatar
M@cDreamy
tats the thing i m not sure abt
coz the 6MT and 4AT has different suspension rite?
Old Aug 19, 2005 | 12:43 AM
M-ster's Avatar
yup 6spd and auto4 has different suspension. the 6mt suppose to have sports susp and 4at with stardard susp.
