Daverx
08-15-2005, 05:50 AM
I'm now experiencing a problem....whenever my ride is parked overnite or for several hours, I have difficulties with the steering....It vibrates vigorously! & very stiff to go either left or right!
I've to stop & roll the steering left to right, right to left & left to right........ to let it vibrates for a while & everything will be back to normal! What's happeneing?????
Something wrong with the EPS? Anyone experienced this, I doubt. What about those rides not from Singapore???
:confused: :confused: :confused: :confused: :confused:
Daverx
08-15-2005, 06:06 AM
I've checked with the techy forum....was told that to reset or calibrate the EPS.....
Any bros noe how to do it? thks.............. :eek: :eek: :eek:
Daverx
08-15-2005, 06:21 AM
wats EPS?
Electric/Electronic Power Steering......
M-ster
08-15-2005, 06:28 AM
Duh! silly me...
Anyway... sounded serious!
maybe try disconnecting your battery. that will reset a couple of electronics. Unless you know exactly which fuse to pull out...
Daverx
08-15-2005, 06:33 AM
Duh! silly me...
Bro.. thanks...
hmmm....maybe will try to....
i've posted this problem at the tech section hopefully our 8s bros overseas can assist..... seemed some oreadi faced problems regarding the steer but not the vibration part......
keep my fingers crossed!
thanks bro :p :p :p
M-ster
08-15-2005, 06:41 AM
If you really pulling the battery, remember this, the DSC light will come on, to dis-enage, turn your steering all the way left then rigth (or the other way round cant remember) that will re-set the DSC.
And hopefully the EPS too....
good luck
Genesis
08-15-2005, 09:11 AM
Daverx...not really sure what would cause that to happen, but the 8 does benefit from a decent electrical grounding like circle earth from HKS....just a thought.
coupe07
08-15-2005, 11:38 AM
zavhan had that problem before... some electrical fuse i tink.. u may wan to check with him
Daverx
08-15-2005, 08:28 PM
roger dat.............
thanks bros......i'll do & check what u guys have suggested.....hopefully it works.....else .......*sigh* :p :p :p
Hi Bro,
Yeah, I'am having the same problem. Already spoken HY workshop at Ubi and they will contact the Jap to understand what cause this.
I have read some threads and they did mentioned to replace wire harness and Power steerring module to resolve the problem.
I will continue to chase them and call you once found out the cause.
Did you just change Battery!!
Daverx
08-16-2005, 12:47 AM
Hi Bro,
Bro...thanks
same car same time having same problem..... :)
thanks
