Compression braking?
Old Jul 16, 2003 | 10:57 PM
8_wannabe's Avatar
Go baby!
Ok, a question for you gearheads... Can you do compression braking in a rotary just like a piston engine? One of the new buyers said he dropped it into 4th looking for 6th and the car didn't slow a bit; it just revved the engine. Yes, I know a Wankel has a compression cycle just like a piston engine yet it doesn't fight against the upstroke like reciprocating engines do. It just keeps on rotating in the same direction as the power stroke. Can anyone analyze this for us?
Old Jul 17, 2003 | 02:23 AM
daedelgt's Avatar
Re: Compression braking?
Compression braking works just the same. Even a 5th to 4th shift in my FD causes the car to decelerate quite a bit faster. That'd be nearly the same as a 6th to 4th in the 8.
Old Jul 17, 2003 | 02:51 AM
wakeech's Avatar
mostly harmless
sure it'll work... i wouldn't recommend doing it, but yeah, you can engine brake.
Old Jul 17, 2003 | 07:03 AM
mdmaclean's Avatar
Why don't you recomend it? I currently often engine brake (6-4 downshift) when approaching a highway exit. Often, with that single shift, I never have to use my brakes. It also places me in the gear I need for the street, so the shift was inevitable.
As long as you take the time to reasonably match the revs, it does not seem evil to me. Does this place more stress on rotary engines than piston ones?
Old Jul 17, 2003 | 08:34 AM
wakeech's Avatar
mostly harmless
...this is why i advocate searching and reanimating old, dead threads...
* MUAH HA HA HA HA!!! LIIIIIVE!!!! *
Using Engine Break <- i know it's spelt wrong, but i wasn't the one who started the thread...
Old Jul 17, 2003 | 10:03 AM
8_wannabe's Avatar
Go baby!
Thanks. I started this thread and I did search for engine brake/braking. I am not too interested in engine breaking. If I wanted that, I'd be on a Ford forum.
Old Jul 17, 2003 | 11:08 AM
Sputnik's Avatar
Well, regardless of the debate of whether one should or not, I can tell you from experience that the rotary engines won't engine brake like a piston engine.
---jps
Old Jul 17, 2003 | 02:10 PM
SA22C's Avatar
Oversteer = Bliss
Yeah, my SA doesn't engine brake worth a damn, but then again, that's why God invented brakes, right? To me, it's better to be hard on the consumable parts, like brake pads, than the non consumables, like the motor and transmission. If you're intent on downshifting while slowing down, match revs. Your engine will thank you. :D
gwailo
May 14, 2024 06:57 AM
RXFEVER
Aug 29, 2018 10:14 AM
RXFEVER
Sep 11, 2016 02:51 PM
airlive
Sep 7, 2015 08:32 PM
