Resseting the CZ UNIT
Old Jul 29, 2005 | 03:19 PM
Lock & Load's Avatar
Thanks to mazdamaniac i have finally been able to install possibly the 1st CZ unit in an Australian car
Theres a definite improvement in accellaration , smothness right through the rev range. :D
Mybutt dyno tells me around 20 hp gain
After 3 days i noticed that the stock ecu computer has tried to resett itself to its old parameters .
Whats the correct procedure to resett the cz unit ?, is it possible to install an on off switch inside the car to allow easier ressetting ?
I HAVE DONE A SEARCH BUT I AM NOT 100% SURE HOW TO RESETT THE UNIT .
B...Free
michael
Old Jul 29, 2005 | 04:50 PM
You need to reset the ECU in the car...not the CZ. The ECU will set fuel trims if the CZ is tuning in closed loop areas.
MM had a thread on resetting the ECU................
Old Jul 29, 2005 | 05:17 PM
Yeah i know i have to reset the ECU in the car , in order to get it back to the standard flash then re switch the cz unit back on .
I have a fair idea how to do this but will wait till i am 100% sure . :D
I have searched for that thread by jeff so far no luck
B...free
michael
Old Jul 29, 2005 | 05:25 PM
r0tor's Avatar
not sure if the 20 brake taps trick with the car not running and ignition turned to "ON" will reset the ecu of an aussie car. If not, pulling the battery cable should do it.
My guess is if your butt didn't become recalibrated and your car really did learned the settings so quickly, you will need to edit the map and try to blank out things under ~5500 rpms.
Old Jul 29, 2005 | 05:28 PM
THANKS GUYS I HAVE FOUND THE THREAD THAT WILL RESET THE ECU
https://www.rx8club.com/series-i-tech-garage-22/ecu-clear-reset-27548/
B...free
michael
Old Jul 29, 2005 | 07:04 PM
Jeff (M azdamaniac) rocks :D
B.....free
michael
Old Jul 29, 2005 | 07:48 PM
Nemesis8's Avatar
Bigus Rotus
Yikes - another tuner in Australia
Jelliott5384
Oct 26, 2016 05:15 PM
olyrx7
Oct 26, 2015 09:23 AM
ShellDude
Oct 1, 2015 09:55 PM
Stubbs
Sep 27, 2015 04:06 PM
mattymack
Sep 6, 2015 10:33 PM
