grinding when down shifting!!
Old Jul 24, 2005 | 02:45 PM
projectcar's Avatar
i got the srmotor sports heavey duty clutch and flywheel, along with the clutch hose.. the problem arises when im down shifting from third to second... a grinding noise happens. now i just got back from a drive, it started to do it from first to ssecond now.. really i cant stand this noise, and feel like im killing my car. pleaese suggestions!!!!
Old Jul 24, 2005 | 02:55 PM
ZoomZoomH's Avatar
Mulligan User
sounds like the clutch isn't fully disengaged, have you checked your clutch line, make sure it's fully bled?
Old Jul 26, 2005 | 07:58 AM
projectcar's Avatar
what about....
do you think it's due to the short shifter i installed, and not engauging correctly?
Old Jul 26, 2005 | 09:15 AM
ZoomZoomH's Avatar
Mulligan User
well grinding usually happens when someone tries to shift while the gearbox isn't fully disengaged.
i'm assuming that, before you intalled the clutch/flywheel, your short shifter was functioning normally, and you had no grind. if that is the case, then more than likely something went wrong during the clutch/flywheel install, and the clutch is unable to fully disengage when shifting, hence the grind.
theblinkof
Oct 4, 2023 05:24 PM
WranglerFan
May 31, 2022 07:51 AM
WranglerFan
Nov 5, 2017 09:35 AM
XianUnix
Sep 29, 2015 03:48 PM
