Is this normal?
Old Jul 19, 2005 | 12:00 AM
peralwhite8's Avatar
Is this normal?
Problem is that inside my RX8-AT either too hot or too warm... even at outside tem is around at 55-60... always putting out warm or hot air from the vent.. So my AC is always working when driving... I heard that RX8 engine gets pretty hot but is this normal?? anyone having the same issue? Also when I took my vechicle in because of bad CD player and told them this issue they just said that it's normal for RX8...
Old Jul 19, 2005 | 07:34 AM
jenkins-crew's Avatar
Hit the AC button :D It isn't normal, take it back to the dealer if you still have problems, mine is really cold.
Old Jul 19, 2005 | 02:02 PM
you mean COLD without the AC?? I'm talking about when AC is not on
Old Jul 19, 2005 | 02:49 PM
Nemesis8's Avatar
Bigus Rotus
The 8 is a hot car it seems lately...
Where is the intake for the vents coming from?
Old Jul 20, 2005 | 10:10 AM
w0rm's Avatar
PUSHER ROBOT
By default air source is set from external. With the fan OFF and AC OFF I often used to have HOT air come out of the vents.
Basically, engine heated air was coming out the vents with everything off. Switch it to recycle cabin air and the problem will go away.
That is, if I understood your problem correctly.
Old Jul 20, 2005 | 10:21 AM
RedSheDevil's Avatar
.:. causing mischief
I believe there is an A/C TSB out...do a search, I know this has been mentioned many times before. And no, it's not right. It may have some extra heat in the cupholders (all the better to keep my tea warm) but should not be a hot car (temperature-wise that is)
Old Jul 20, 2005 | 11:23 AM
Rx8honey's Avatar
In Exile
There is a TSB out on it. I just read it. Do a search you should find it. If not go to finishlineperformance.com and read it there.
Old Jul 20, 2005 | 11:40 AM
brothervoodoo's Avatar
RainMan is Back
When the AC is OFF, are you sure you have the recirculating air set to NOT get air from the outside?
RevMeHarder
Jun 1, 2026 02:30 PM
tommy26Germany
Sep 29, 2015 10:33 AM
Jb4ker96
Sep 27, 2015 10:06 PM
yapakanichi
Sep 25, 2015 07:55 PM
