RX8manual re : sparkplugs
Old Jul 18, 2005 | 01:27 AM
Lock & Load's Avatar
After searching and reading various suggestions some totally incorrect idecided to consult my own RX8 MANUAL AND TO MY SUPRISE THIS IS WHAT I HAVE FOUND .
File Type: bmp
Old Jul 18, 2005 | 02:03 AM
takahashi's Avatar
How surprising.... ... a misprint?!
Leading is NGK 9 and Trailing is NGK 7 - seems to be the other way round?!?!?!
Certainly when I took out mine it was marked 7 on the L plug and 9 on the T plugs.
Calling Mazda for you now in Melbourne...... it is ..... $75. each
Old Jul 18, 2005 | 02:14 AM
Taka i was quoted $78 for trailing plugs and $ 44 for leading ones
Also according to this you need 3 different type of plugs .
1 RE7A-L leading side
2 RE6A-L leading side
1 RE9B-T TRAILING side
B...free
michael
Old Jul 18, 2005 | 02:23 AM
takahashi's Avatar
I will take 7A-L and 9B-T thx
Old Jul 18, 2005 | 02:25 AM
WHATS THE DIFFERENCE ???
hotter plug ?
B..free
michael
Old Jul 18, 2005 | 02:38 AM
takahashi's Avatar
You have to match the fuel that you are using. You are using 7L and 9T anyway, why go hotter plugs? Unless you are not fanging your car anymore than 6L will do.
If you have seen my plugs the L plugs came off second best to the T plugs.
Just go stock, or you are a rev head, get the Denso or NGK racing plugs which are 9L and 10T.
Old Jul 18, 2005 | 03:26 AM
aa@uow's Avatar
As I have said in another thread, Mazda Australia has replaced my spark plugs with modified version, to reduce exhuast gas emissions... not sure what type of modified plugs they have given me...
Old Jul 18, 2005 | 04:48 PM
Finally found the site for NGK Australia.
http://www.ngkspark.com.au/
B....free
michael
Old Jul 19, 2005 | 02:54 AM
lexic's Avatar
Dealer said that they have now placed upgraded plugs in mine, as well as upgraded starter motor and upgraded battery. Apparently a directive from MA that older rx's are getting these upgrades to help with starting issues.
Old Jul 19, 2005 | 03:02 AM
Can you get us a copy of the work they have done under warranty showing the directive from Mazda Australia ,
I WANT TO TAKE THIS UP WITH MY DEALER
B...free
michael
Old Jul 19, 2005 | 03:13 AM
lexic's Avatar
B...free
michael
i'll have a look through the paper work that I have and see what it says, my dealer never gives me paper work for warantee stuff, but I have requested a copy. Will let you know.
Old Mar 11, 2018 | 01:53 PM
bbyatv's Avatar
I checked the resistance on the 4 plugs in my car and found 3 to be at 3.9 kilohms and 1 to be a 5 kilohms. Wondering if this could cause a mis? The spec range is 3 to 7.5 kilohms.
Old Mar 11, 2018 | 01:59 PM
Loki's Avatar
It's in spec, so I would look elsewhere for cause of misfire. Like the coils.
train460
Mar 2, 2008 12:21 AM
sosonic
Sep 19, 2007 06:48 PM
venksta
Canada Forum
13
Sep 25, 2006 03:58 PM
jjkayak
Canada Forum
Mar 17, 2006 12:40 AM
EpRAnGia
9
Dec 2, 2004 06:04 AM
