View Full Version : drilling hole in throttle plate - solution to rough idle issue?
brillo
07-16-2005, 01:09 AM
I was kicking around the idea of buying a new throttle plate and drilling a small hole in it to allow more air in when idling as I have read before about people doing this mod on other cars.
since we have no way to adjust idle otherwise, carefully drilling a small hole and enlarging it until you get to the desired RPM might be a easy solution. My aim in this is to get rid of the vibration we feel at idle.
Any thoughts or issues on this? would the DBW system throw a fit?
expo1
07-16-2005, 01:17 AM
Please excuse the noob sounding question but what problem does this vibration at idle cause? I kind of like the way my 8 sounds at idle with my Greddy SP2.
brillo
07-16-2005, 01:26 AM
it doesn't cause any problems other than just being annoying
swoope
07-16-2005, 04:47 AM
brillo,
how much difference the revi make on your car??? as far as idle is concerned, made a huge diff on mine.
next week i think dealer is going to replace plugs and check motor mount. new batt, blah blah.
btw i am at ~29k miles it was getting worse with time. think a lot of it is plugs, but the revi settled it down a lot.
TeamRX8
07-16-2005, 09:56 AM
I have a 2005 RX-8 and don't have an idle issue, I would propose that you find the problem and fix it rather than attempt to bandaid it. FWIW, the idle control motor will only attempt to compensate for a drilled hole. If it gets too far outside it's workable range of adjustment you may only cause a worse problem.
mikefrombarrie
07-17-2005, 10:43 PM
I keep on reading threads about rough idle. I too have bad idle, but in my opinion its not a negative thing. I'm saying this becasue I driven acouple of more expensive sports cars eg, NSX, 911 turbo etc.. And they all had "rough" idle
If I had a luxury car and it had a "rough" idle it would bother me. but since the rx8 is a sports car isnt the idle suppose to be rough??
zoom44
07-18-2005, 12:51 PM
in my opininion "rough idle" is because we are less insulated fromand closer to the working bits of the car.
zoom44
07-18-2005, 12:53 PM
oh and the crazy swapping of firing order at idle
guy321
07-18-2005, 12:54 PM
It has to do with the flashes.. I never had a jerky stick till I went to N..
Blacknightz
03-22-2011, 01:15 PM
anyonez done this? advisabe?
Stray
03-22-2011, 01:23 PM
Holy thread necromancing.
Drilling a hole in the throttle plate just sounds like a terrible, horrible idea. Take it to the dealer and make sure it has most current flash first. Then check mounts, and then ignition.
laythor
03-22-2011, 01:32 PM
lots of other things to check on before breaking out the drill bits becomes an option
and to blacknitz, bravo for searching! wish more people did it
04Green
03-22-2011, 05:13 PM
Looks like an old question, but....
Car idles smooth as silk with decent plugs/coils, and MAF is clean. One other thing is check grounds. They can mess with it as well.
$100 thread has this and a few other things.
bse50
03-22-2011, 05:27 PM
We have means to adjust our throttle electronically now, drilling the TBwould just be stupid.
Rx8s don't have a rough idle, if yours is then it's time to do a check.
alz0rz
03-22-2011, 05:51 PM
Horrible.
EdwardsB
03-22-2011, 06:04 PM
wasn't there a flash for this a few years back? To smooth the idle out and reduce vibration. check to see if this was done.
edit:
Found it: MSP-16
http://www.finishlineperformance.com/pdf/rx8/bulletin/01-013-08-1925.pdf
03-22-2011, 09:00 PM
this is a stupid idea. whoever bumped this thread needs to die.
tiltmode43
03-22-2011, 11:49 PM
He searched, found a question that wasn't necessarily resolved, and bumped for an answer. Searching is a good thing, not a reason to die.
That said, for anything reading this in the future: if idle is rough, checking the ignition system + motor mounts would be the first step.
WTBRotary!
03-23-2011, 12:26 AM
Lol... Yes :yelrotflm:rofl::bowdown:
Blacknightz
03-23-2011, 07:11 AM
Cheers mate...
i dont mind themz... these 'people' always exist...
Anyway reason being... I had idling issues... the rpm would drop like it was going to die and came back alive...
Jeff, Mazdamaniac said my MAF was reading like crazy...
It was showing alot of air or compensate the loss of air or something along those lines....
After dismantling the 'whole car' i believe it was the throttle body or the fuel pump... Checked fuel pump was still ok... i thinkz... So check throttle body...
It seemed clean... Rotary specialist and authrorised one to boot, recommended to drill a tiny tiny hole if i wanted to save cost... As he mentioned that even throttle body has wear and tear...... ie worn out...
so just wondering if others has done it, and if it affects anythinz in the long run...
if not... just have to purchase a new throttle body... u might be surprised that it was kinda not so easy to get these just from searching the web... mostly found USED conditions ones.
http://cgi.ebay.com/ebaymotors/Throttle-Valve-Body-747440-ASSY-LIFETIME-WARRANTY-OEM-_W0QQcmdZViewItemQQfitsZModelQ3aRXQ2d8QQhashZitem5 1982186f0QQitemZ350444685040QQptZMotorsQ5fCarQ5fTr uckQ5fPartsQ5fAccessories
have seen a couple of those big throttle body.. looks nice but not surez if it is a plug and play....
http://cgi.ebay.com/ebaymotors/UNIVERSAL-DNA-80MM-THROTTLE-BODY-CNC-BILLET-ALUMINUM-_W0QQcmdZViewItemQQfitsZModelQ3aRXQ2d8QQhashZitem2 30f2e928dQQitemZ150578565773QQptZMotorsQ5fCarQ5fTr uckQ5fPartsQ5fAccessories
http://cgi.ebay.com/ebaymotors/performance-80mm-intake-throttle-body-cnc-billet-rx7-_W0QQcmdZViewItemQQfitsZModelQ3aRXQ2d8QQhashZitem4 83f9f4403QQitemZ310305047555QQptZMotorsQ5fCarQ5fTr uckQ5fPartsQ5fAccessories
nycgps
03-23-2011, 08:44 AM
I sense a lot of fail coming ...
04Green
03-23-2011, 09:31 AM
Add grounds, especially for an older one. Do not need the full blown kit, just make sure they are snug, a little electrical grease does not hurt either.
