ONLY 188.8 RWH with turbo
Old Jul 14, 2005 | 03:12 PM
youngpit's Avatar
I just got back from turbotrix in edison nj and my poor rx8 only got 188.8 with the turbo i will post the chart later gotta scan it. what could the problem be just let me know i am a little P#$ed
Old Jul 14, 2005 | 03:15 PM
chrism's Avatar
Misfit Moderator TnC
what kind of dyno is it?.....is your ecu tuned?.....what psi was that at?
Old Jul 14, 2005 | 03:16 PM
lurch519's Avatar
www.evoperform.com
sounds like you might have a boost leak somewhere, or maybe detonation and the ecu was pulling timing. dont know. what octane fuel are you running. check all intake pipe connections
zoomzoom_8's Avatar
did you disconnect the rear speed sensors so the ecu did not sense that the front wheels were not moving and kick the car into limp mode to keep you from losing control?
Old Jul 14, 2005 | 03:24 PM
brothervoodoo's Avatar
RainMan is Back
I've seen a lot of 8's dynoed with none pulling the rear ABS sensors and they still pulled 170-180 rwhp on a dynojet. I know some have mentioned this as a possibility of causing "limp mode" but I don't buy it. I would recheck your turbo setup. But why not "break out" that old argument again.. haven't heard it come up in awhile... :p :p https://www.rx8club.com/series-i-engine-tuning-forum-63/limp-mode-16738/
EDIT....
With the GT package, did you hold down the DCS button for 10 seconds before dynoing??
Old Jul 14, 2005 | 03:27 PM
xdrian's Avatar
Banana Yellow :P
damn why didnt you tell me, i work 2 min from there.
did they dyno in 5th gear?
did you disconnect sensor fuse?
what turbo?
what psi?
Old Jul 14, 2005 | 03:32 PM
xdrian's Avatar
Banana Yellow :P
dyno is a awd dynojet
Old Jul 14, 2005 | 03:37 PM
Xyntax's Avatar
THREAD KILLER
ouch
Old Jul 14, 2005 | 03:38 PM
zoomzoom_8's Avatar
I however do buy the wheel sensor removal before dynoing. I was with a friend who dynoed a turbo eight before I had my turbo on (have not dynoed mine yet) and he only got like 154 wheel horsepower. Wheel sensors were not disconnected because he did not have his lug key. so it makes real sense to me, also make sure dsc is turned off by holding it for ten seconds. Other than that, something is bad wrong with the dyno or your setup. how does it feel when driving?
Old Jul 14, 2005 | 03:54 PM
Broke_Apex_Seal's Avatar
when you put the 8 on the dyno the system defaults. It is just a myth!!!!!!! It is the shitty emanage it blew my car up
Old Jul 14, 2005 | 04:43 PM
tazzydnc's Avatar
why dont you just compare 0-60 times before and after or street start or whatever... isn't that what really matters?
Old Jul 14, 2005 | 04:54 PM
Fanman's Avatar
AWD tends to take a lot more off the driveline. They usually take off 25% driveline loss for that. Don't know if your car (a RWD) on an AWD dyno would still lose that or not (AWD Dyno registering it differently)
Old Jul 14, 2005 | 05:12 PM
zoom44's Avatar
how did the rwd drive car drive thefront rollers ont he awd dyno?
what was your baseline number on tha tdyno?
Old Jul 14, 2005 | 05:55 PM
Richard Paul's Avatar
The front rollers are not connected when you run a RWD car. So it makes no matter.
Maybe his car has the same virus mine does. HP worms.
Old Jul 14, 2005 | 06:24 PM
adrian-1's Avatar
Ex- member.
Post the dyno graph.
If your hp curve stops going up after 6k rpms, your having the problem I did. The map was way too rich. Got it tuned and its better now.
I got mine tuned today also on a dynojet. I got 218hp/ 180tq, much better than the 194hp/164tq I had on a mustang dyno.
Check this thread for the 2 different dyno graphs and how tuning it leaner fixed my problem.
Old Jul 14, 2005 | 06:32 PM
Marietta 8's Avatar
I guess I'll save the 4 grand and be happy with the 204/146 I got w/out the turbo!
Old Jul 14, 2005 | 06:51 PM
adrian-1's Avatar
Ex- member.
Also, on the dynoruns we didn't disconnect the wheel sensors.
We only removed the DSC/ABS fuse in the fuse box (60A). The traction control light came on but no CEL and no loss of power.
Check this thread for my running rich / lossing power problem.
I need to see the dyno graph before saying thats your problem also.
Old Jul 15, 2005 | 12:20 AM
So it is true.............
Remove the fuse and it works!
Old Jul 15, 2005 | 12:49 AM
adrian-1's Avatar
Ex- member.
Yup. It's a bigger fuse, not the regular small ones. Also, don't panic after you put it in and the TCS/ABS lights are still on. Once you drive above 10mph they'll clear.
Old Jul 18, 2005 | 05:56 PM
youngpit's Avatar
ok i will get the chart up asap i have been on vac and working like a dog dame drug dealers and gang bangers keep me busy.... i went back to where i go the turbo installed and he checked every thing and all was goo there the only thing he said it miight be if the plugs so i am getting new plugs colder onens and new wires and try again.. I THANK YOU ALL FOR ALL THE HELP YOU GUYS /GALS ARE THE BEST!!!!
Old Jul 19, 2005 | 03:33 PM
jwbond's Avatar
I was at turbotrix last saturday and my bro got his evo dynoed. it appears there is something wrong with their dyno. he pulled about 40-50 less hp than expected. the guy after him got new cams and had a 10hp drop. so it seems that there is something wrong with the dyno there, try calling them and seeing what is up.
did you have to hang out in their lot ALL DAY for a dyno pull that should have taken no more than an hour too?
Old Jul 19, 2005 | 04:27 PM
Fanman's Avatar
I tried to dyno my car a few weeks ago at my regular place & the dyno basically failed. Said their magnet was going bad. Well, this blows.
Hunterkelley24
Series I Engine Tuning Forum
Jun 14, 2022 08:32 AM
galognu
Rotary Swaps
138
Nov 16, 2020 05:20 AM
JimmyBlack
273
Feb 10, 2020 10:23 PM
05rx8mazda
Nov 28, 2015 09:42 AM
MolecularConcept
11
Sep 29, 2015 09:21 PM
