Possible to control Cat temp sensor?
Old Jul 13, 2005 | 06:02 PM
r0tor's Avatar
Just wondering if anyone knew of any aux inputs to the e-manage that would let you adjust/fake the output from the cat temp sensor. I'm thinking even something as simple as above 6500rpm cat temp = 1650 deg F or a way to rescale the sensor so it would max out at 1650 deg F.
If you do some logging you will see after just a bit of hard driving the cat temps will increase drastically and the computer goes from pig rich to super-duper pig rich. There has to be a way around this i'm thinking.
Old Jul 14, 2005 | 02:07 AM
therm8's Avatar
Bummed, but bring on OU!
you could probably use a simple zener regulator circuit to clamp the voltage at whatever temperature you want. you'd just need to know what the voltage is at 1650F. this is assuming the temperature sensor is an RTD.
Old Jul 14, 2005 | 05:35 AM
sco's Avatar
sco
And that is assuming that a sensor exists. Cat temp is derived as a function of a number of engine parameters, not from an actual sensor.
Notice there is no sensor on the wiring diagram, nor any DTCs that talk about cat temp sensor input high or low.
Cheers
sco
Old Jul 14, 2005 | 06:57 AM
therm8's Avatar
hmm, well nevemind :p
and what a ridiculously stupid way to "measure" temperature. :D
Old Jul 14, 2005 | 07:04 AM
r0tor's Avatar
Cheers
sco
hmm, guess your right... well that idea just got shot in the *** : :o
http://www.freepatentsonline.com/4656829.html
Looks like the calculation is running primarily on the MAF and O2 sensor. The e-manage already is manipulating the MAF, but it looks like to control the cat temp you would also need to mess with the O2 sensor since the a/f ratio seems to be a bigger determining factor then airflow according to delphi.
Old Jul 21, 2005 | 01:48 PM
HD-Paschke's Avatar
http://www.airfuelmeter.com/english/...ata_german.pdf
The LSU4.2 have a termo Sensor inside.
MikeTyson8MyKids
Nov 12, 2022 11:54 AM
drebbrnator
Dec 27, 2018 07:02 PM
nivong
Europe For Sale/Wanted
Sep 2, 2015 07:54 AM
tgaffner
Aug 20, 2015 10:55 AM
Jvswan
28
Jul 23, 2015 09:02 AM
