Avons vs potenzas
Avons vs potenzas
I was looking for new tires online and I came up with these two:
http://www.tirerack.com/tires/tires....e1=yes&place=2
http://www.tirerack.com/tires/tires....ech+M550+A%2FS
I think the potenzas I found are the stock ones on the 8. Please correct me if I'm wrong. For the specifications, the Avons looked like the best ultra high performance all season tires out there. I'm wondering if the ratings are the same between summer and all season. Going by the chart the Avons are better than the potenzas in every way (handling, traction, ride quality and noise), yet are priced cheaper than the potenzas... I want something all season but I dont want to lose any performance that I have with the stock tires. Are the avons the way to go?
Well, I'm a little confused. Looks to me like, the Avons are summer high performance, but have a snow traction rating
. They fared very well in the surveys, and not too bad on the track. And the price is very good.
My biggest complaints with the Re040s was the noise and the price. Tread wear wasn't too bad for me, 25k before replacing. Switched to KDW2s, personally, but after 16k, they are becoming as noisy as the Bridgestones. Their grip is amazing, though.
Edit: nevermind about the summer high performance. just looked that way from the tests.
. They fared very well in the surveys, and not too bad on the track. And the price is very good.My biggest complaints with the Re040s was the noise and the price. Tread wear wasn't too bad for me, 25k before replacing. Switched to KDW2s, personally, but after 16k, they are becoming as noisy as the Bridgestones. Their grip is amazing, though.
avons are ultra high performance all season, not summer. They are in my opinion much better than the potenzas. I've been running them for about 1500 miles now, and the road noise is less, grip is better during rain, and car feels a lot smoother. for the first 300 miles there was a bit of tire squirm but that went away. For a cheaper tire to outperform the stock tires like that really amazed me.
I have the 550s and am very pleased with them. Less road feel (and noise) with the softer sidewalls then the 040s but the 550s handle cool wet weather much better. Haven't had them in the snow yet. Did I say less noise? I can hear the engine and transmission now and can talk normally and not have to yell over the tire noise. And the price was right.
I've been riding them for a few months now (about 4k) and love them. The softer sidewall is definitely noticeable, making you feel a hair less 'connect' to the road at first (I got used to it in a few hundred miles). However the resulting reduction in noise is staggering. The grip is excellent in all conditions I've been in so far (no snow yet). The tread life should also be about twice that of the potenzas. With the improvements in tire compounds in recent years, I feel that dedicated summer tires wont be around for much longer.
As for the low cost... from what I hear they are trying to break into the US market. But I didn't buy them because they were cheap, rather because the had the best reviews and specs. The price was just a nice bonus. I will definitely buy them again, even if they cost as much as the other big names when I need my next set.
How do they compare to....pirelli pzero
I was wondering how the AVONS compare to Pirelli pzero Nero m&s? I'm looking for a tire that will work well in all seasons including some light snow (I"m in Washington DC). Any other recommendations would be appreciated.
-also I understand that 245/40/18 will also fit on stock rims. Will this dramatically reduce winter/wet performance?
Best,
Jonathon
Best,
Jonathon
Keep in mind that you're comparing the SURVEY results of the tires. I don't know how well you can compare a survey of one tire to another.
You really want to compare the Tire Rack test results.
Here's the Avon, but I can't find the break down of the test results, which would let you compare specific features of each tire against each other, instead of an average performance rating.
http://www.tirerack.com/tires/tests/...ech+M550+A%2FS
I can't find a page for the Bridgestone test results, not sure they tested that model.
Refer to my post, https://www.rx8club.com/showpost.php...78&postcount=4, for virtual shoot-out. Cliff notes summary: Get PZero Nero M+S if you do not autocross or Toyo Proxes 4.
Originally Posted by pcimino
.....Here's the Avon, but I can't find the break down of the test results, which would let you compare specific features of each tire against each other, instead of an average performance rating......
which takes you to http://www.tirerack.com/tires/tests/..._m550_as_c.jsp
Tires for my new 8
This is some great info. I've been convinced not to buy the Bridgestone to replace the two old tires on my 8 (too loud). For the same price it looks like I can get 4 of the Avons (never heard of them though). I was also looking at the BF Goodrich g-force. Its a great looking tire! Any thoughts on them, or any experience with them?
i just put a set of Avons on and though I only have 50 miles on them....so far...not to impressed. I'll see in a few hundred miles fi they get any better......they are a hell of a lot quieter!
In summary,
With the Avon tires (when switching from the OEM ones), I lost:
- Some steering accuracy
- Some steering response
- A small amount of confidence when taking turns
... I gained:
- A quieter drive (makes a big difference if you commute in the RX8)
- A slightly less bouncy ride
- A good amount of confidence when driving on a wet road
- Probably better traction in the snow (haven't tried this yet)
T-REX
Just got my Avons and will keep you posted on snow.
I don't mind the softer ride (for a commuter, it's actually a blessing) and the rain traction seems to be excellent. They are definitely quieter. Hopefully, they will handle the light snow expected in about a month or two around here.
codesterb91
Nov 16, 2015 05:57 PM
dweezil22
NE For Sale/Wanted
12
Sep 9, 2015 10:50 AM
cschoeps
Aug 6, 2015 12:44 PM
geaves
9
Jun 13, 2005 08:39 AM
TCReedy1
May 16, 2005 01:11 PM
