Need advice from someone with wheel and tire experience
I am starting to think down the road to when I will replace my wheels and tires. I want to stick with 18's, but I want to go wider than the stock wheels. Also, my wheels/tires are inset a bit from the wheel well, and I want the new ones to at least be flush or maybe just slightly outside of the wheel well (nothing as extreme as a lowrider or anything). Can anyone recommend a width that they have used to achieve this effect? Also, do I need to be considering different offsets to get the desired effect, or will a wider wheel do it? I am completely clueless about what offset is. Thanks
I have 19" on my car & my rims & tires are perfectly flush with the outside on the wheel well. For 18" I would recommend 18" x 8.5" with a +35/+30 mm offset on the front with a 245/40/18 & the rear go with a 18 x 9.5" with a +35mm offset with a 275/35/18 tire. Don't lower the car more than 1" & you should be fine (no rubbing).
Thanks for the suggestions. While we are at it, can someone explain what offset means? I don't want to just repeat what someone said when I go to get my wheels and tires. I want to know what I am talking about.
offset is where (plus or minus) the wheel mounts to the hub...and 0 offset is dead center of the wheel +35 offset is 35mm out (closer to teh outside of the car) -35mm offset is 35mm in (closer to the hub) :D
i believe teh stock rims are =50mm offset...but don't quote me.
hope that made sense
codesterb91
Nov 16, 2015 05:57 PM
dweezil22
NE For Sale/Wanted
12
Sep 9, 2015 10:50 AM
ian_rxviii
Aug 10, 2015 02:00 AM
