Loud ticking noise on startup
Old Jun 28, 2005 | 05:24 PM
SHAG1's Avatar
Unhappy Loud ticking noise on startup
When the engine is cold and I start it up, there's a loud ticking noise which lasts for a minute or so. I checked the oil level and it's fine. Does anyone have this problem or know whats going on?? Please help.
Old Jun 29, 2005 | 11:45 PM
clmantis21's Avatar
is your car a Manual transmission and does the ticking noise vary at all when the clutch is depressed?
Old Jun 30, 2005 | 02:10 PM
SHAG1's Avatar
It's a manuel trans. I haven't tried depressing the clutch when the noise occurs, but i'll try it next time. Is this a typical issue with the manuel trans?
Old Jun 30, 2005 | 02:14 PM
wedge357's Avatar
ShinkaMan #748 SV6P
the same metal parts that cause ticking noise when you turn off the engine can also cause ticking when you start a cold engine. Metal expands and contracts causing the ticking.
Old Jun 30, 2005 | 02:46 PM
silver1.3's Avatar
I think - and i stress think its the air pump (or some similar device) Mine does the same exact thing.
Just on a side note, whats the temp. when you start the car?
Old Jun 30, 2005 | 03:51 PM
zoom44's Avatar
yeah it could most likely be the air pump since thats when its most used.
Old Jun 30, 2005 | 04:19 PM
SHAG1's Avatar
The Loud ticking noise only occurs when the engine has completely cooled, ie. sitting on the driveway over night. It last for about a minute and then goes away. Once the engine is warm, the noise no longer exist.
Old Jun 30, 2005 | 05:09 PM
wedge357's Avatar
ShinkaMan #748 SV6P
I rest my case. :D
Old Jun 30, 2005 | 05:10 PM
SHAG1's Avatar
Thanks for the info guys!
Old Jul 5, 2005 | 11:06 AM
MyRxBad's Avatar
Fb's rock!
I get the same noise with my car when I fired it up in the morning. I've decided it's normal and probably the air pump that's pre-heating the cat.
Mane
Nov 20, 2015 12:16 PM
nowakm99
Oct 9, 2015 07:10 AM
tommy26Germany
Sep 29, 2015 10:33 AM
FubarI33t
Sep 28, 2015 08:45 PM
Jb4ker96
Sep 27, 2015 10:06 PM
