Melted Plastic got on the bulb HELP
Old Jun 21, 2005 | 07:24 AM
slllygrl10's Avatar
EX-Member
I was messing with the high beams and I sat it on something then next thing I knew melted plastic got on the bulb how do u get this off?
Old Jun 21, 2005 | 08:09 AM
Coop '04's Avatar
DELIVERED 07-17-2004
Razor blade?
Old Jun 21, 2005 | 08:25 AM
Raz0rama's Avatar
I am the God of Hellfire!
Be careful, any scratch on the surface could cause the bulb to explode when it heats up. They run very hot. When you get it clean, make sure you wipe it off thoroughly with a soft cloth to remove any oils from your hands. A clean new steel razor blade should work to remove the plastic, since it is softer than the surface of the glass, apply light pressure and make sure there's no dirt or dust trapped beween the blade and the glass.
Old Jun 21, 2005 | 09:01 AM
ZoomZoomH's Avatar
Mulligan User
just get a new highbeam bulb (or bulbs if they only come in pairs)
better be safe than having bulb blow up in the headlight housing
Old Jun 21, 2005 | 10:04 AM
Nubo's Avatar
Lubricious
I 2nd the new bulb recommendation. High-output halogen bulbs are pressurized and "explode" is not an exaggeration. The bulbs themselves are made out of fused quartz, not glass, to withstand the high temps. This works well, but once the quartz becomes contaminated it can weaken suddenly. Even touching a new bulb with your fingers can contaminate it enough to eventually lead to failure.
Old Jun 21, 2005 | 11:15 AM
Raz0rama's Avatar
You can get a new bulb for probably around $40 for a set.
Old Jun 21, 2005 | 12:52 PM
slllygrl10's Avatar
EX-Member
Do u clean the bulb with alcohol?
Old Jun 21, 2005 | 01:20 PM
army_rx8's Avatar
X-Sapper
new bulb..anything on it can cause it to blow when it is on...just get a new on..and don't use your highbeams until you do.
(granted alchole will evaperate off of it..but why take teh chance of it blowing anyways...how much is a new bulb
Old Jun 22, 2005 | 01:47 AM
Yes, use rubbing alcohol. It might take awhile to get the plastic off.
Old Jun 22, 2005 | 09:07 PM
slllygrl10's Avatar
EX-Member
I removed the melted plastic it works yay
Old Jun 26, 2005 | 06:28 PM
truemagellen's Avatar
Attracts tree branches
how did u do it?
Old Jun 27, 2005 | 07:11 AM
slllygrl10's Avatar
EX-Member
Originally Posted by truemagellen
how did u do it?
I carefully scraped it with the blade
ÜberJumper
Canada Forum
21
Feb 20, 2025 11:57 AM
RXFEVER
Aug 29, 2018 10:14 AM
arexatemate
Oct 9, 2015 06:23 PM
XianUnix
Sep 29, 2015 03:48 PM
projectr13b
Series I Do It Yourself Forum
Sep 6, 2015 01:04 PM
