JL subs RF pro series T3002 = 140+ db!
Old Jun 9, 2005 | 10:00 PM
sandnsun7's Avatar
Cool JL subs RF pro series T3002 = 140+ db!
Did this install myself:
Extended faceplate, custom painted grills and amp rack cover over the trunk well. Stenciled and cut out the RX-8 on the cover.
Used black material from a fabric store to stretch over 1/2" plywood and particleboard for the box. 2- 10" JL Audio W1v2's, pushed by a Rockford Fosgate pro series T3002. Bridge mono for around 500 watts. Now i'm tightening down car rattles in the rear of the car! Sound quality is awesome in all ranges due to the amp control. So much low end, I have the bass setting on the stereo -1 to 1, depending on the type of music. The amp has an 18 db boost **** control, with a frequency boost **** adjustable from 35-90 Hz. A true audiophiles crank toy! Mounted it in the ashtray to keep it hidden. Adding aluminum red grill material behind the RX-8 cutout to match the speaker grills.
Tell me what you think. Thanks.
Old Jun 10, 2005 | 12:09 AM
FastRX8's Avatar
IstanbulNotConstantinople
Bass Envy!
Sounds cool. I'd like to see some pics.
Maybe I can get mine to sound that good eventually. I have the same subs, but I'm having a problem.
Works great when only one it connected, but both connected sound terrible.
If you have any ideas, here's the thread.
https://www.rx8club.com/series-i-interior-audio-electronics-24/help-jl-audio-subs-jl-audio-amp-%3D-no-bass-63677/
Anyways, your system sounds like what I'm trying to acheive.
Congrats,
- Cesar -
Old Jun 10, 2005 | 03:29 PM
TRU681's Avatar
Just curious, what mic did you use to measure the DBs. 140+ with JLw1 is hard to imagine. I have 2-12 ich Eclipse titaniums 750watts rms amped by a Phoenix Gold titanium 1000.2 bridged with birthsheet of 1200watts & my whole car has been dynamat extremed but I have not measured the SPL yet because I"m a SQ guy but if you hit 140db+, I think I'll hit at least low 150s.
Old Jun 18, 2005 | 11:15 PM
Kel Rx8's Avatar
if your not 1st your last
pls make life easier and add a pix
Old Jun 20, 2005 | 10:21 AM
MrWigggles's Avatar
For two medium power 10", 140 is pretty high up there even for a small car like the RX-8.
More importantly for Sound Quality it is more bass than you should ever need.
-Mr. Wigggles
galognu
Rotary Swaps
138
Nov 16, 2020 05:20 AM
bosstin87
Oct 5, 2015 06:52 AM
xAgyex
Sep 28, 2015 08:54 AM
Learners_Permit
Sep 27, 2015 07:38 PM
