Ignition key not turning
Old Jun 6, 2005 | 06:14 PM
No More Oldsmobiles's Avatar
Custom User Title:
Twice in the last two days I've had this problem. The key would not turn in the ignition for several minutes. I would remove it, jiggle it, try turning it while pressing in, not pressing in, light pressure, hard pressure, etc. The last time I thought I was going to have to call a tow truck. But I kept at it and it eventually turned with complete smoothness.
Please note that I have never had a problem turning it until just the last two days, and I've owned the car since the first of the year.
What do you think? Should I spray some WD-40 in it? Or is this a problem for the dealership?
Old Jun 6, 2005 | 06:26 PM
Khabriel's Avatar
it has happened to me a couple times..but if u turn the sterring wheel a bit while turning the key..it should work...it might be the key lock thing...im not quite sure what its called..but its a security feature i think..its also like that on the ml320...hope this helps
Old Jun 6, 2005 | 06:56 PM
Go48's Avatar
Yeah, Khabriel is probably correct. It's called a steering wheel lock. Turn the steering wheel L or R as you turn the key. That should do it.
Old Jun 6, 2005 | 06:59 PM
kachud's Avatar
Mad Scientist
Are you using the right key? Just kidding
Old Jun 6, 2005 | 11:59 PM
DreamWarrior's Avatar
yeah, I'd go with wheel lock...happens if you turn your wheel with the key out...it'll stop turning and lock, then make it hard to turn the key..... That's why I don't touch the wheel after I pull out the key...but I guess it's a security feature...no key, no turn....
Old Jun 7, 2005 | 02:32 PM
Custom User Title:
Thanks for the answers, everyone. I figured it was part of the anti-theft system, but I couldn't figure out why the key wasn't turning at all. If this happens again, I'll try tugging on the steering wheel to see if that frees up the key.
JimmyBlack
273
Feb 10, 2020 10:23 PM
Anthony Kevin
Sep 7, 2015 07:36 PM
projectr13b
Series I Do It Yourself Forum
Sep 6, 2015 01:04 PM
Emmanyei
Sep 4, 2015 11:38 PM
