View Full Version : aftermarket rims information
ibfubar2000
07-08-2003, 08:24 PM
im sure this is the wrong area, but i know they mods will move it. but the rx-8 workshop manual is online for dealers. and looking at the tire pressure monitor. it is attached to the valve stem. so any wheel will work, just have to swap the valvestem/control unit with the new rims. anyway just thought you guys would like to know!
brothervoodoo
07-08-2003, 08:57 PM
Ibfubar2000,
Thanks for clearing that up, I know a number of people were interested in knowing that information.
thanks.
zoom44
07-08-2003, 09:06 PM
heh i was thinking the same thing earlier. thanks for the confirmation.
pmacwill
07-08-2003, 09:28 PM
*wink*? *wink wink*
I'd sell my soul...
right click -> save webpage -> zip -> and post
ibfubar2000
07-08-2003, 09:53 PM
sorry it is password protected. mazda does not want non mazda techs to have this info.
ZoomZoom
07-08-2003, 10:13 PM
Anyone know or care to speculate when 15 or 16" steelies will be available for the 8? I've got to get some prior to winter coming.
brothervoodoo
07-08-2003, 10:20 PM
Did you get the GT with the bigger brakes? I've read on this board that 16' rims may not fit.... :eek:
eccles
07-08-2003, 11:59 PM
looking at the tire pressure monitor. it is attached to the valve stem. so any wheel will work, just have to swap the valvestem/control unit with the new rims.... as long as the OEM wheels don't have some sort of proprietary design in the vicinity of the valve stem hole. One would hope not, but on the Technical Hiughlights CD thay did say that the system was incompatible with aftermarket wheels. Guess we'll have to wait and see.
SPDFRK
07-09-2003, 12:10 AM
Fubbie,
since you have access can you tell us what the wheel specs are ie... backspacing and bolt pattern/diameter?
ibfubar2000
07-09-2003, 04:56 PM
i dont see anything that specific about the tires. i will ask the tech though next time he comes into my office and ask him where i can find it at. <p>
i did find info on the oil though:
Item Recommended oil
API service SL
SAE viscosity 5W-20
ILSAC GF-3
Oil capacity (Approx. quantity)
L {US qt, lmp qt}
Item Oil capacity (Approx. quantity)
Oil replacement 3.6 {3.8, 3.2}
Oil and oil filter replacement 3.8 {4.0, 3.3}
Engine overhaul 5.0 {5.3, 4.4}
Total (dry engine) Standard power: 6.1 {6.4, 5.4}
High power: 6.9 {7.3, 6.1}
zoom44
07-09-2003, 05:27 PM
ahh can you translate that fubes? i'm not sure i understand what you posted there. wha does " Oil replacement 3.6 {3.8, 3.2}" and the rest of the numbers mean?
ibfubar2000
07-09-2003, 05:42 PM
oil replacement means if you drain th oil from the oil pan refill with 3.6l. if you drain with replaceing the oil filter fill with 3.8l. if you overhaul the engine fill with 5.0l and if the engine is completely dry(ie new engine) fill with 6.1l. {the number in the brackets are us qts and impqts}
zoom44
07-09-2003, 05:53 PM
man i am dense today and my typing sucks!
Farsyde
07-13-2003, 01:26 PM
so does that mean the valve stem monitors are RF or some other wirelesss signal???
eccles
07-13-2003, 03:35 PM
Originally posted by Farsyde
so does that mean the valve stem monitors are RF or some other wirelesss signal??? Yes.
