KONI shocks with RB spring
Old May 25, 2005 | 03:36 AM
redish 8's Avatar
racing beat s offering Koni shocks
159 for front
145 for rear
so total is $204 US for a set of 4
and it say that i can use with the racing beat spring
so what do you guys think??
or should i just go with the Tein S spring just sping itself
Old May 25, 2005 | 06:56 AM
djmano's Avatar
RX-8 Pilot
i wish it was $204 for the set! its the prices are for each individual shock........so more like 320 for the front set and 290 for the rears. ~600 bucks for the shocks.
Old May 25, 2005 | 09:19 AM
cretinx's Avatar
And I got my coilovers for under $650 . . . . there's a world of difference between shocks/springs and coilovers.
Old May 25, 2005 | 04:01 PM
NoCones's Avatar
You down with 13B?
Not necessarily. You can make good and bad choices with either.
Old May 25, 2005 | 06:15 PM
Mikelikes2drive's Avatar
are these konis the adjustable ones?
and i dont see why coilovers would have an advantage over spring/shocks setup
Old May 25, 2005 | 07:55 PM
Dark8's Avatar
Ride Naked!
Coilovers come with damping matched to their spring rates. Buying adjustable shocks from one company and some other companies springs can be a problem if they don't play well together. That being said, the Konis have a pretty wide range of adjustment and would probably work well with most springs available for the RX-8.
Old May 26, 2005 | 05:02 PM
DPE's Avatar
DPE
The Konis should work well with about any aftermarket spring for the RX8, as Dark8 alluded to, because they are adjustable over a very wide range. We just got a set on one of our cars last weekend, with no other mods. At a half turn up from full-soft in the rear and a similar setting in front, they are definitely firmer but by no means harsh. Feel just about like what the car should have felt like from the factory; taut, better controlled, and more responsive without killing the ride. Dropping the fronts to full-soft made it essentially feel like a stock car, just with more damping in the rear (did not adjust the rear yet, since you have to remove them to adjust).
Over the next couple months we'll be experimenting with them on the road and track, and eventually trying a couple different spring and swaybar combos as well. If you would like a set, DPE has 6 sets ready to ship for $585, with free shipping through the end of the month. Also have free shipping on Tein S-techs through the end of the month and three sets in stock; they're $160. Feel free to PM or email with any questions, or if it all just sounds perfect you can place your order directly on the site .
Regards,
Phil
Driven Performance Equipment
sales@dpeweb.com
www.dpeweb.com
Old May 26, 2005 | 05:38 PM
brothervoodoo's Avatar
RainMan is Back
TheDosDog has this exact setup and has made comments on some recent threads.
Old May 27, 2005 | 10:47 PM
Koni's did their research using the RB springs.
They're a perfect match.
Old May 28, 2005 | 07:02 AM
rxeightr's Avatar
M0D Squad -charter member
Wish they were available when I put my RB springs in this late winter.
Old May 29, 2005 | 01:33 PM
Me too... The extra expense isn't worth it at this time. I think I'm going with the flywheel for my next modification instead of shocks.
duworm
Oct 1, 2015 04:57 PM
Turman-ator
11
Sep 22, 2015 11:22 AM
Paul_Y
Sep 21, 2015 02:23 PM
Sakebomb Garage
Group Buy Center
Sep 12, 2015 08:18 PM
