Porting RX-8?
Old May 24, 2005 | 04:46 PM
HardHitter's Avatar
Porting RX-8?
How much and how long do you think porting an RX-8 would be? Would there be a sufficient amount of HP gain or would it be cheaper/easier to get a PTP/SSR/Greddy turbo whenever they came out (I know Greddy's is out)
Old May 24, 2005 | 04:57 PM
lurch519's Avatar
www.evoperform.com
porting requires removing and disassembling the entire engine, porting it, then reassembling the motor and reinstalling it, several days at least. much labor, probably in the neighborhood of at least 2000. see moderate gains, maybe 25 horse.
greddy turbo kit takes about 12 hours to install, and can see gains of about 40 to 50 percent.
Old May 24, 2005 | 04:58 PM
zoom44's Avatar
search for the thread by guitarjunkie. hes the onethat does renesis porting that has talked about it on here
Old May 24, 2005 | 05:06 PM
zoom44's Avatar
https://www.rx8club.com/series-i-major-horsepower-upgrades-93/great-renesis-porting-project-45052/ someoen was saying search wasnt working well. thats just one of the threads but should get you started
Old May 24, 2005 | 07:58 PM
HardHitter's Avatar
So do you suggest I port the engine first in order and then wait until my warranty is up to get a turbo? There is a local RX-7 here that has a turbo and ported engine, and first thing, that thing is VERY loud sorta sounds like a V8 throaty sound, and it's pushing around 500hp to the wheels. Very very quick car.
Old May 24, 2005 | 09:55 PM
rotarygod's Avatar
Porting will void your warranty too. Personally I always recommmend porting as the last thing you should ever do to your car as it is one of the most expensive for the amount of return. Don't even worry about it right now. Do everything else first and it last.
Old May 24, 2005 | 10:18 PM
Diabolical RX8's Avatar
Drift Fanatic
Well if I had the $ to choose between porting and turbocharging. I would have to go with porting it first then buying a turbocharger later on.
But thats just what I would do. It is totally up to you though.
Old May 24, 2005 | 10:23 PM
brillo's Avatar
Go Texas Longhorns!
I agree with RG on this one. I'm all for making the engine as efficient as possible, but unless your 8 is a second car, and you can do the work yourself, porting is not worthwhile at this point IMO. Bang for buck, greddy turbo is still your best bet.
Old May 24, 2005 | 10:35 PM
Nemesis8's Avatar
Bigus Rotus
I think there is work that can be done from seeing the engine down at Racing Beat. And then reading the work that Rotaryheads are doing is really cool. For $2550 you can get 9% gains...
Old May 24, 2005 | 10:42 PM
Well depends upon EPA and CARB certified.
Would a ported engine pass SMOG?
Yes, it's expensive, but then again you never have to remove the turbo for smog.
I've known shops that will not smog a car because the intercooler was on the car.
Even thogh components are disconected and they see them, some shops will fail the car on the visual test.
They know you are going to re-connect the turbo so they fail you.
Old May 26, 2005 | 08:59 AM
shelleys_man_06's Avatar
Not anymore
After crushing Hussain's fluid mechanics course, best bet is to go with forced induction. Mass flow rate is your friend.
Old May 26, 2005 | 09:21 AM
cretinx's Avatar
But if you port it first, you would be ported to NA spec - FI has different demands and requirements, so you'd have to report it again.
Old May 26, 2005 | 07:36 PM
Hellbreed's Avatar
Putting the warranty issue aside, would you not get a better return on your FI if you port or rather polish the exaust ports? Would you not get more power out of it at the same boost?
Old May 26, 2005 | 10:51 PM
rotarygod's Avatar
Probably but remember that the Greddy kit is sized to work with the stock engine and not a ported one. It's not to say that it won't work with a ported engine but everything needs to be designed as a complete package.
Old May 26, 2005 | 10:55 PM
devious12's Avatar
Flame Thrower
No one has cracked into the greddy system yet?
Old Jun 1, 2005 | 05:26 PM
slavearm's Avatar
Boost Junkie
I would personally go FI then when you eventually blow your engine <Slavearm Ducks Behind a wall> get it ported while getting rebuilt. That way you don't pay to rebuild the engine twice =)
That's my plan anyways.
Slavearm
PS-I know as soon as I get FI... the boost will keep going up till I blow something. This may or may not be the case for everyone else.
Old Jun 1, 2005 | 07:04 PM
RotorManiac's Avatar
Absolute Rotary Madness
lolz you make it sound like its routine to you!
an engine blown a day keeps the mechanic away (oh well...)
Old Jun 7, 2005 | 08:32 PM
StealthFox's Avatar
what...
Old Jun 12, 2005 | 07:11 PM
Originally Posted by StealthFox
what...
I hope you can see the irony in my words
Old Jun 12, 2005 | 07:14 PM
NoTears316's Avatar
Shock and Awe
Exactly, unless you have money to burn, it's not worth porting until you need a rebuild.
Slavearm
Old Jun 14, 2005 | 09:37 AM
D1GT-x8's Avatar
well i wanted to do a port polish job after i get my turbo. so with that said should i
a) wait for a company to make a low compression rotors then get it p and p. or
b) get it now. and if so what power gain in percentage would i be seeing.
rotory god have any suggestion. or anyone else if that. Im getting the P&P regardless.
the horse power im trying to get at is 500 or maybe 600 if possible.
Old Jun 21, 2005 | 08:02 PM
StealthFox's Avatar
d1gt, id like to do what your doing, port polish (maybe something like bp aux ports) lower compression, improve fueling, up the boost on a SFR/SSR or custom to get big HP
Old Jun 21, 2005 | 08:12 PM
Richard Paul's Avatar
the horse power im trying to get at is 500 or maybe 600 if possible.[/QUOTE]
Rots a Ruck
JimmyBlack
273
Feb 10, 2020 10:23 PM
RXFEVER
Aug 29, 2018 10:14 AM
RXFEVER
Sep 11, 2016 02:51 PM
czr
Sep 13, 2015 11:37 AM
