Spark Plug Confusion
Old May 23, 2005 | 12:44 PM
MDRX8's Avatar
The trailing plug is NGK RE9B-T.......WHAT IS THE TRAILING PLUG? RE7A-L OR RE7C-L???????
Thanks Guys
Old May 23, 2005 | 12:55 PM
ranger4277's Avatar
Cones need lovin' too!
Did you mean to say leading in there someplace?
Old May 23, 2005 | 01:29 PM
Go48's Avatar
Thanks Guys
I believe RE7A-L was the original leading plug, and the RE7C-L is the newer leading plug of a somewhat different design as I understand it. Check with Rosenthal or Trussville to see if they have the newer leading plug.
Old May 23, 2005 | 01:58 PM
MDRX8's Avatar
leading plug
Thanks Guys
What is the leading plug???? Been a long day........
Old May 23, 2005 | 05:18 PM
Jellybean's Avatar
How about having a look at the Specifications page in your owner's manual as a starting point?
Old May 23, 2005 | 05:25 PM
Nemesis8's Avatar
Bigus Rotus
Leading Plug
The factory OEM replacement plugs made by NGK (RE7AL)
Trailing Plug
The factory OEM replacement plugs made by NGK (RE9BT)
Old May 23, 2005 | 07:16 PM
takahashi's Avatar
leading plugs the first set of plugs in the rotary cycle
trailing plugs the second set of plugs int he rotary cycle
Old Mar 11, 2018 | 03:35 PM
bbyatv's Avatar
RE7A-L OR RE7C-L
The C-L has notches the A-L does not. See pic.
Old Mar 12, 2018 | 11:09 AM
NotAPreppie's Avatar
What am I doing here?
Nice 13 year thread necromancy...
RevMeHarder
Jun 1, 2026 02:30 PM
DylanForbes
25
Oct 31, 2017 05:47 PM
1.3_LittersOfFurry
Sep 22, 2015 01:54 AM
Vedivan1
Sep 18, 2015 12:39 PM
Irvinb16
Sep 11, 2015 10:27 PM
