replacing bose amp?
Old May 22, 2005 | 04:17 PM
ammachama's Avatar
replacing bose amp?
Hi,
I have an extra amp at home and was thinking about using it in my car. I was wondering if anyone has done this and if so, what wires are the high level inputs from the factory stereo. I have a feeling it's the two sets of wires that are surrounded by the grey coating, but I just wanted to be sure.
I have already done a search for this, but came up empty!
Thanks for your help!
Old May 24, 2005 | 12:00 AM
rx8squared's Avatar
search has been funky lately. if it works there are a lot of threads about this. good luck.
Old May 24, 2005 | 10:26 AM
smrx8's Avatar
the search feature been acting up lately
Old May 24, 2005 | 01:06 PM
forbidden's Avatar
djseto is correct. The grey lines that you see are the premp lines that run from the head unit to the amp in the rear parcel shelf. DO NOT tie into these lines if you are keeping the stock system intact. If you are adding something like a sub, tie into the rear 6x9" speakers at the speakers themself. There is a way to do this system properly and a way to do it improperly, which way do you want to go?
Old May 24, 2005 | 01:59 PM
ammachama's Avatar
thanks for the response!!
I will do another search and see if I can find something!
What I am trying to do is get rid of the bose amp and bose speakers. I have an extra phoenix gold amp that has high level inputs - couldn't I just hook the grey covered wires into this new amp??
I have already added the sub - and I did just splice off the rear 6x9s
hopefully I will figure someting out!!
thanks again!!
Old May 24, 2005 | 02:17 PM
forbidden's Avatar
That would be a no. What you need is the Audio Control 6XS to do the job properly. This device you can integrate into the factory preamp lines. Contact me by e-mail at forbidden@telus.net for more info.
Old May 24, 2005 | 05:07 PM
ammachama's Avatar
thanks for your help!
looks like I might eventually get some decent sound in my car!!
rotarywanker
Dec 8, 2022 05:56 PM
delicious_dallan
Jan 17, 2020 09:17 AM
ei8ht
Aug 21, 2017 09:08 AM
CMRine04
Jul 27, 2015 09:46 PM
yapakanichi
Jul 21, 2015 08:43 PM
