Battery Disconnect
Old May 16, 2005 | 12:57 AM
Jellybean's Avatar
Battery Disconnect
I, regrettably, have to leave my car for three months.
I've searched to see whether the car will forget any vital information if I simp[ly disconnect the battery before I go and reconnect when I return and I can't find anything that worries me.
However, since I am aware that the blokes on this forum know EVERYTHING, I thought I might check whether there is a problem with what I intend to do. Please tell me if there's something I should know.
Ron
Old May 16, 2005 | 01:12 AM
Tim Tam's Avatar
Ron, maaaaaaaaaaaaaaaaaaaaaaaaaaaate. I will gladly look after your car for you while you're gone!!!! :D :D :D
Old May 16, 2005 | 01:31 AM
takahashi's Avatar
Don't listen to Ron...
I think it is ok mate. She will still recognise your touch when you come back. I don't think it will run away for another bloke. :p Her brain (ECU + flash) will be the same.
She may become forgetful and does not remember your fav radio station or how long you have been going out with you (ie. the Trip meter :D only not odometer).
Old May 16, 2005 | 02:52 AM
timbo's Avatar
rock-->o<--hard place
I don't know that disconnecting the battery is wise, becuase of all the information potentially kept in (volatile?) memory.
It may be better to have the battery connected to a trickle charge or similar...or have someone give it a drive at the mid-point of your absence
Might be worth looking what our North American colleagues do over winter, when many store their cars to avoid de-icing salt
Old May 16, 2005 | 03:44 AM
EZZY's Avatar
cry me a river...
i have disconnected the battery when i went to uk last year.
read the manual, when re-connecting the battery... you will have to do a few things, cant remember them now.
Old May 16, 2005 | 04:13 AM
takahashi's Avatar
name one timbo!
Well you centainly have to reset the DSC by turning from left limit to right limit.
Change the clock
and
Reset your present radio stations.
Old May 16, 2005 | 05:01 AM
xxup's Avatar
Originally Posted by takahashi
...Well you centainly have to reset the DSC by turning from left limit to right limit...
Huh???? Left limit??? Right limit????
Old May 16, 2005 | 05:28 AM
EZZY's Avatar
cry me a river...
thats right, from memory, turn the key tro ignition and do full lock from centre to full left and then full right (or the other way)
Old May 17, 2005 | 01:44 AM
mikeyr's Avatar
i need a new photo
And don't forget to leave the hamster some extra food! You'll never get that rotor spinning again without it!
Old May 17, 2005 | 07:32 AM
sco's Avatar
sco
Disconnecting the battery is fine. Guys in the US do it all the time for winter. I've done it for six weeks. When you reconnect you'll have do the full lock to full lock for DSC, reset the auto down on the drivers window and set the clock and radio.
Ideally, put the battery on an automatic charger, but if you can't or are worried about leaving it on for 3 months then make sure the battery is charged.
Old May 17, 2005 | 04:03 PM
Jellybean's Avatar
Thanks, folks, for your advice -- I appreciate it.
Tim, I had thought to have you mind my car for a couple of months but, with the Winning Blue blokes so fussy about their colour, I didn't want you to blow your credibility with them just before your own WB turns up by being seen around town in a lowly Velocity Red.
Ron :D :D
92trbolzr
May 18, 2025 09:04 AM
cliffkemp
Dec 24, 2024 10:48 AM
Shankapotamus3
Mar 14, 2021 03:53 PM
Evan Gray
Sep 26, 2015 12:30 PM
