Removing resonator?
Old May 15, 2005 | 01:23 AM
BIU's Avatar
BIU
Removing resonator?
I tried searching but didnt find anything that i wanted...
Just wondering if any of you have removed just the resonator on the 8?
Im running a JIC catback..... just thought that i could get a little more sound from teh exhaust if i removed the resonator...
any feedbacks is appreciated...
Old May 15, 2005 | 02:30 AM
Fanman's Avatar
Resonator is part of the pipe that includes the cat. Cat just remove the resonator, unless you buy one of two things. There are straight pipes that remove both. There are hi-flow cat units that remove the resonator portion from RP & SR Motorsports.
Old May 15, 2005 | 03:16 AM
BIU's Avatar
BIU
could i get a muffler shop to cut off the resonator and reweld a pipe back on to teh resonator section so i would retain the use of the stock cat?
Old May 15, 2005 | 10:04 AM
Charles R. Hill's Avatar
Owner of BHR
You might be able to but the resonator is a straight-flow design that has little to no restriction to it. I am told that the noise of an unsilenced rotary is quite deafening. I am using a catless midpipe w/resonator and that is pretty loud by most standards. Most are using a high-flow cat with a silenced mid.
CRH
Old May 15, 2005 | 11:42 AM
MazdaManiac's Avatar
Removing the resonator will just make it really buzzy. If you like the sound of a weed trimmer, then go for it.
Old May 15, 2005 | 12:05 PM
Owner of BHR
Yeah, there is definitely a "buzz" in the exhaust sound w/o the resonator. I always describe as an "overgrown chainsaw". Same thing.
CRH
Old May 15, 2005 | 12:07 PM
dazygirl415's Avatar
I had a cat w/o an exhaust for a few days and it was unbearably loud and very buzzy. Stick with a midpipe or hiflow cat w/the exhaust.
Old May 16, 2005 | 09:17 AM
foxman's Avatar
Torque is Good
I am running the SR Motorsports mid pipe with no resonator and it is not buzzy at all with a cat back exhaust. It is considerably louder than just a cat back. I will tell you that running no resonator with the stock exhaust IS buzzy and not at all pleasing to my ears.
mid pipe (no res) with stock exhaust
https://www.rx8club.com/showthread.p...=exhaust+video
mid pipe (no res) with cat back exhaust
What a local FD owner says about how mine sounds after some burn in
https://www.rx8club.com/mw-rx-8-forum-31/foxmans-8-best-sounding-rotary-evar-55457/
mdl0209
May 23, 2019 05:46 PM
Racingjunkie
Sep 29, 2015 05:05 PM
xAgyex
Sep 28, 2015 08:54 AM
Learners_Permit
Sep 27, 2015 07:38 PM
