Brake Noise
Old May 13, 2005 | 07:12 AM
Titanium Rocket's Avatar
Titanium Rocket
Brake Noise
I've had my RX8 for 4 days and I am noticing a noise after I put the car in reverse and then drive forward. It seems like the noise is simultaneous with the release of the brakes. Is this normal?
Old May 13, 2005 | 08:24 AM
Go48's Avatar
Probably the ABS system doing it's calibration thing, assuming it only happens one time when you first move out.
Old May 13, 2005 | 08:29 AM
Wurmfist's Avatar
FEAST!
Does it go away once you start driving? Mine stays garaged during the week and the moisture we are having right now really rusts my discs bad. But as soon as I get it out of the driveway the noise goes away and so does the rust.
Old May 13, 2005 | 08:56 AM
Go48's Avatar
Like I said, it only does it's calibration thing one time, shortly after you move the car and after it has been parked for some considerable period of time. If you park it overnight or longer, it will make the sound again--one time.
The rust has nothing to do with the ABS calibration sound I'm refering to. But if you apply the parking brake with the pads wet, and the car is parked for a time, the pads can "freeze" (i.e., rust) to the rotors and you may hear a pop sound when you first move the car as the pads break loose from the rear rotors. The rust on the rotors is not a mechanical problem as lon as your car doesn't sit for months without moving. It's basically an appearance problem. As you indicate, it will scrub off after a few brake applications.
Old May 13, 2005 | 09:00 AM
sable's Avatar
mine does this too - both things mentioned. ABS when you first move car and brake freeze after rotors get wet and car sits and they dry. perfectly normal.
Old May 14, 2005 | 03:43 PM
Titanium Rocket
Thanks for the replies -- I feel so much better! I LOVE this car!!!!
hufflepuff
May 30, 2016 10:45 AM
Oct 3, 2015 09:51 AM
D13
Oct 1, 2015 07:55 AM
tommy26Germany
Sep 29, 2015 10:33 AM
Jb4ker96
Sep 27, 2015 10:06 PM
