Lightest Exhaust
Old May 10, 2005 | 01:12 PM
RotaryManiac's Avatar
1st time rotorhead
Lightest Exhaust
What is the lightest cat-back exhaust and the price if known?
Old May 10, 2005 | 01:17 PM
army_rx8's Avatar
X-Sapper
hehe no exhaust :p
seriously probable one of the titanium ones..but they are hella exspensive
Old May 10, 2005 | 01:20 PM
a 20 gauge stainless steel straightpipe
Old May 10, 2005 | 01:24 PM
MrWigggles's Avatar
The Titanium JIC's are really light (I believe that is the company name). I think they are about 60% lighter than stock.
Also consider the RP super cat (and some of its issues). It is 11lbs which is 11lbs lighter than stock.
-Mr. Wigggles
Old May 10, 2005 | 01:38 PM
LiL BenNy's Avatar
Bubblicious? DEF.
^^ jic titanium..
Old May 10, 2005 | 02:38 PM
1st time rotorhead
RP supercat is a cat-back system right? How much does it cost? By the way, i believe the stock exhaust is 39 pounds.
Old May 10, 2005 | 04:05 PM
Fanman's Avatar
No the RP Supercat is the replacement for the catalytic/resonator part of the piping. The stock one weighs quite a bit. The SR Motorsports & RP units save about 10-12 lbs. from that section. That cat back goes from the end of the RP supercat.
Old May 10, 2005 | 07:24 PM
1st time rotorhead
Oh. Sorry so the cat-back system goes on after the supercat. it doesnt come with its own converter?
Old May 10, 2005 | 07:49 PM
RotorManiac's Avatar
Absolute Rotary Madness
hey nice nickname you almost stole mine :D
I guess, by the way, I have one of the lightest exhausts, my titanium Trust catback is only 4.8kg, search for 'titanium' and you will find my thread... its somewhere around here...
Old May 10, 2005 | 08:42 PM
1st time rotorhead
Haha, great name. How much did it cost you? And did you also get a HP gain?
Old May 11, 2005 | 12:17 AM
Fanman's Avatar
No, that's not the way it works. From the engine it goes in 3 parts : 1) Exhaust manifold (also called the header) 2) Catalytic convertor & resonator (also called silencer) 3) Cat back system (includes pipe & mufflers).
The RP & SR Motorsports replace part #2.
The Cat Back exhaust systems replace part #3
Old May 11, 2005 | 12:33 AM
preach on fanman! haha
Old May 11, 2005 | 12:52 AM
Humba sala hum ba....................................
The Rotory God has spoken
Old May 11, 2005 | 07:53 AM
I wasn't able to dyno the car, but it felt good, especially at medium-high rpm range.
well, as you already know it is expensive... as a part it costs 150,000JPY, but that's in japan, I got it in my hands at about 1350euros.
Old May 11, 2005 | 09:23 AM
Spin9k's Avatar
Momentum Keeps Me Going
Cork Sport Catback $599
mid pipe 7.0 lbs === stock was 5.4 lbs
muffler 18.8 lbs === stock was 33.6 lbs
----------25.8 lbs-------vs stock------39.0 lbs
Old May 11, 2005 | 12:03 PM
1st time rotorhead
Is the cork sport steel or aluminum? Anyone have it? Hp gains?
Old May 11, 2005 | 12:42 PM
aluminum would melt on a rotary engine exhaust
Old May 11, 2005 | 12:45 PM
ddub's Avatar
always preoccupied.
Actually no it wouldnt. Aluminum works fine....
Old May 11, 2005 | 12:48 PM
well I've seen it melt on a reciprocating engine exhaust
Old May 11, 2005 | 12:51 PM
ddub's Avatar
always preoccupied.
Well my ported 2nd gen rx7 has aluminum exhaust, been about a year and a half now... Remember, the rotor housings are aluminum too.
Side note to this thread. Has anyone thought about making a custom setup at an exhaust shop? Say putting a single muffler where the piping is still straight, then run it to the back with dual tips. That could be made pretty light, but it might be a tad loud.
Old May 11, 2005 | 01:01 PM
Fanman's Avatar
I know RB is developing a single exhaust that will drop some pounds off for people looking to reduce weight, without spending tons of money.
Old May 11, 2005 | 01:02 PM
well I suppose if it was thick enough to dissipate the heat, the rotor housing is water cooled, it could probably be lighter with light gauge inconel
read line 2
http://burnsstainless.com/TechArticl...m_article.html
Old May 11, 2005 | 01:08 PM
ddub's Avatar
always preoccupied.
Yes I know the housings are cooled, but still. There are people that run the older peripheral exhaust housings with NO sleeves in the exhaust port, which makes it just open aluminum as the exhaust exits. They have absolutely no problems doing that and I guarantee it's a lot hotter than anywhere else in the system. Because it is the exhaust port there is only coolant above and below to cool, and it's not a lot.
Anyways, this argument is stupid because people will have different beliefs, but I have my catback made of aluminum and it works fine, that's all I have to work off of as well as what the people experience running no sleeves for their exhaust ports to dissipate the heat.
Old May 11, 2005 | 01:10 PM
ddub's Avatar
always preoccupied.
I think that'll look really dumb though since the rx8 has the openings for 2 tips
It looks bad enough when a 2nd gen does it with just cutouts, and I can stand those, but there are actual holes for the rx8 and I think it'd just look odd.
Old May 11, 2005 | 01:22 PM
when you're racing it looks a lot odder when you're staring at your competitors exhaust pipe rather than the other way around
most racers aren't out there to be pimping around the track
