Oil Cooler Grill
Old May 9, 2005 | 07:46 PM
shinka213's Avatar
Pettit fangurl <3
Oil Cooler Grill
here's a couple of pix I took....lighting was not so great.....of the oil cooler grills I put in over the weekend...nothing fancy about them...more practical and protective than elegant....easiest thing about them was I cut them out and just fit them in without taking the bumper off....
Attached Thumbnails Oil Cooler Grill-shinkaoilcoolerscreen1.jpg   Oil Cooler Grill-shinkaoilcoolerscreen2.jpg
Old May 9, 2005 | 07:51 PM
tiggerlee's Avatar
May Cause Anal Leakage
They actually look pretty good. Are they attached with anything or are they just sitting in there?
Old May 9, 2005 | 07:55 PM
shinka213's Avatar
Pettit fangurl <3
Actually, they are just sitting inside....I cut them so they would fit tight.....they havent budged yet under extreme speeds I might add....
bought the stuff at home depot....a roll of it.....a really cheap but effective mod
Old May 9, 2005 | 07:57 PM
tiggerlee's Avatar
I just got the material myself last weekend but, didn't really want to remove the bumper to do the install. Cool idea! I may have to try this out. Thanks!
Old May 9, 2005 | 08:26 PM
shinka213's Avatar
Pettit fangurl <3
the roll I got was called " 1/4in hardware cloth" and I cut it on an angle so when installed it had the diamond look instead of squares....I rolled it slightly to fit in and then pushed it to flatten....I made a small cut out to fit around the fog light...
Old May 10, 2005 | 09:35 AM
Cattywampus's Avatar
Turbos blow!!
Nice. Are you going to paint it?
edit: guess not since it's already installed
Old May 10, 2005 | 10:44 AM
rx8wannahave's Avatar
Follower of CHRIST!!!!!!!
Nice! Hopefully I'll do this mod soon, I hope...I'm a little worried I'll do something stupid.
Note: If one day I want to install the factory fog lights...will oil cooler grills cause a problem, the home made version I mean?
Old May 10, 2005 | 03:16 PM
shinka213's Avatar
Pettit fangurl <3
I could paint them if I want to....they are easy to take out since they arent really fastened with anything...as far as the fog lights are concerned....not really sure about that but if you dont fasten them you should be able to take them out, install the fog lights then make some cuts on the grills to refit....or you could actually cut new ones....the stuff is really cheap...you could make new ones every year for the life of the car with the same roll..
Old May 10, 2005 | 10:28 PM
bmcc49er's Avatar
I kind of like it as is unpainted. What do you plan on doing for the AC condenser?
Old May 11, 2005 | 11:52 AM
MadDashRX8's Avatar
Resu Deretsiger
Nope. You can actually install them right up against the oil cooler/between it and the rubber boot. This keeps them completely out of the way of the foglights. It's what I did on mine :D :
Old May 11, 2005 | 12:56 PM
Morgan's Avatar
Lounge Sweetheart
wow..yours is all blinged out! lol.
i''d do it if i didn't have to remove the front end.
Old May 11, 2005 | 06:35 PM
shinka213's Avatar
Pettit fangurl <3
that looks really sweet.......all three matching....what type of material did you use?
I would definitely be up for doing that if I had the where-with-all to take off the bumper, etc....you did a great job!!!
Old May 11, 2005 | 07:42 PM
MadDashRX8's Avatar
Resu Deretsiger
Take yourself down to a Lowe's/Home Depot-type store. The material is expanded steel that comes in the form of a screen door protector for pets and kids. This is a $20 job. Took me about two hours total. Taking off the front isn't that difficult; do a search for instructions. I did this mod a year ago, and felt I needed to repaint it due to the poor coverage of the factory paint. Little darker now. VERY happy with it all and all!
Old May 11, 2005 | 09:26 PM
L8APEX's Avatar
Smooth Criminal
I have seen this done with the fine mesh screen, and it eventually rusts. Then it looks really bad. Taking the nose off is not that hard, especially if you don't have the fog lights.
The second one, maddash's, looks like the holes in the mesh are so big that it will not stop much from getting to the screens. Just an observation. Both look well done though.
Old May 30, 2005 | 09:13 PM
MadDashRX8's Avatar
Resu Deretsiger
Originally Posted by trhoads
IThe second one, maddash's, looks like the holes in the mesh are so big that it will not stop much from getting to the screens. Just an observation. Both look well done though.
I agree; too large of holes. More look than function. That's all I was really going for, anyways. :D
RXFEVER
Aug 29, 2018 10:14 AM
RXFEVER
Sep 11, 2016 02:51 PM
9krpmrx8
Oct 13, 2015 01:36 PM
Sakebomb Garage
Vendor Classifieds
Sep 6, 2015 03:30 PM
