is it possible to switch the tranny?
Old May 6, 2005 | 01:49 PM
Minda's Avatar
yes i have an auto now that I just recently learned how to drive stick I fell in love with it! Im asking you guys if it is possible to switch the automatic tranny to manual...cost does not matter.
Old May 6, 2005 | 01:52 PM
NomisR's Avatar
I'm not going to tell you to do a search.. but it's going to be A LOT cheaper to trade the car in and get a new 6spd rx8
Old May 6, 2005 | 01:53 PM
juniorbean's Avatar
Well, if cost does not matter... then anything is possible.
Keep in mind though that the odds are you'll need to switch much more then just the tranny. You'll probably need to swap out the driveline, ECU, differential, as well as other items that are available on the 6-speed that don't come with the auto... all in addition to the tranny.
It would probably cost you MUCH less money to trade in the auto and get a new stick.... plus, you can keep your warranty if you go that route.
Old May 6, 2005 | 01:54 PM
Glyphon's Avatar
脾臓が痛みました
if cost doesn't matter, trade in your auto and get a 6sp.
and while i'm sure it is possible (anything is possible with enough money), you'd still be stuck with a 4 port, low output engine.
Old May 6, 2005 | 02:48 PM
MTCD01's Avatar
That just means you have to add the Motor to the list of things that need to be swapped.
Motor
ECU
Tranny
Driveshaft
Diff
Intake (not sure if it's the same)
Exhaust (at least the header)
Tach
I think a new MT 8 would be more economical.
Old May 6, 2005 | 02:50 PM
Mugatu's Avatar
Even My Dog Searches
the answer is NO don't do it.
Old May 6, 2005 | 03:46 PM
kuleto's Avatar
you guys just shot down his hope haha
Old May 6, 2005 | 05:46 PM
joseight's Avatar
n00b
yeah, you're better off trading the car in for a manual one.
Old May 7, 2005 | 01:34 PM
snizzle's Avatar
Shakezula, the Mic Rula
my guess is that cost really does matter or this question would be moot
Old May 7, 2005 | 01:43 PM
truemagellen's Avatar
Attracts tree branches
10 grand...
Old May 7, 2005 | 02:04 PM
NAVILESRX8's Avatar
FWD Hater
It's costly, but still relatively simple...there are low-power RX8's sold worldwide with manual trannies.
Just need a Flywheel/clutch setup/correct counter weights
transmission
PPF
drive shaft
starter
ECU
brake master cyl
clutch hydraulics
pedal assemblies
center console
shifter
maybe a 5 speed guage cluster(you can keep the auto one, but it will have PRNDL readout)
The transmission, clutch, flywheel, driveshaft, starter, ecu, console, and guage clucter can be sourced from a euro low power 5 speed
the rest can be sourced localy
Old May 7, 2005 | 02:34 PM
Mugatu's Avatar
transmission
PPF
drive shaft
starter
ECU
brake master cyl
clutch hydraulics
pedal assemblies
center console
shifter
Oh is that all? Sounds simple to me!
Old May 7, 2005 | 03:27 PM
khtm's Avatar
I like rusty spoons
^ yeah where's the DIY for that procedure??
Old May 7, 2005 | 06:01 PM
NAVILESRX8's Avatar
FWD Hater
well...i could do the swap...might take a little while
Old May 7, 2005 | 10:48 PM
Parmer8's Avatar
If cost doesn't matter...how about I trade you my 6sp for your auto + $10k. You won't have the hassle of your car in the shop for a few weeks.
Old May 7, 2005 | 11:16 PM
salituro64's Avatar
Engine is not even the same. Trade it!
Old May 9, 2005 | 07:47 AM
NAVILESRX8's Avatar
FWD Hater
I was just answering the question...is it possible....yes.
But I'm going to advise to trade it in on a 6 speed if you really want a manual tranny RX8.
Old May 11, 2005 | 04:02 AM
allmotorRX8's Avatar
銀い 雪
what they said.... if cost doesnt matter, jus trade for a new 6spd
Old May 11, 2005 | 05:33 AM
Air Force RX8's Avatar
Who Cares?
Did anyone else think this was going to be a post from Abbid until you saw Minda instead? I saw the title and rolled my eyes before I saw who posted it.
Old May 11, 2005 | 09:23 AM
JeRKy 8 Owner's Avatar
Stuck in a love triangle
Is it possible to switch the tranny?
Yup....I did it.
Along with the color, got more accessories, and a navigation system too (which is useless in Miami).
cliffkemp
Dec 24, 2024 10:48 AM
theblinkof
Oct 4, 2023 05:24 PM
Jst4fun
Mar 5, 2021 07:16 PM
Digitz0070
Oct 7, 2015 12:43 PM
