rotary questions
Old Jul 2, 2003 | 05:29 PM
X-R8ed's Avatar
rotary questions
I am new to the rotary, but I would like to better understand it. I know that the rotars control the compression but how does it do this. Is it due to size, shape, thickness.
What would be the negative effects of lowering the compression in order to run higher boost(other than the decrease in horse power). would the loss in power be monumental or would it not really effect the engine performance to much.
Is there a way to increase displacement and if so would that help to increase torque? Or maybe bore the ports out to increase flow or would this end in tragedy.
And last but not least do the seals have anything to do with the performance of the engine other then if they blow thats your @55.
sorry for the newb questions but tryin to learn the ropes of the ol' mighty rotary.
Old Jul 2, 2003 | 06:38 PM
wakeech's Avatar
mostly harmless
hi XR8ed,
the amount an engine compresses its volume is measured by how much volume it sweeps through the compression ratio... on the wankel, there is a fixed maximum because of the inherently fixed cross-sectional geometry (when you look at it from the side, the peritroichoid (sp :p) and fat triangle must be at that fixed proportion)... the compression comes from the rotation aspect of the rotor's orbital movement (where it both rotates around and orbits around the outer gear (which is inside the rotor))... hope you're not confused yet
here is a link to an animated gif which will illustrate this best (i'm not taggin it out of respect for the copyright):
http://www.rotaryengineillustrated.c...es/an-WCA.html
reducing the compression ratio is easy, yes, by grinding out a deeper dish in the rotor. this is quite bad for overall thermal efficiency (smoking fuel consumption and torque when off boost), and is not as good as making the same amount of torque at rpm (power) with less boost and more compression.
no, there is no way to increase displacement unless you get wider rotors, or an entirely upscaled motor (bigger rotors, housings, etc...).
porting is a seldom-understood black art. it's probably not something the average joe would want to endeavor upon unless building a motor for the track (where the more power you can make within the rules and limits of your engine, the better).
by the way: larger orifaces and flow paths DO NOT equate to "freer flow" or "less backpressure". that is a fallacy.
well, yes, seals can have a large impact on performance... the degree to which they seal, and their tolerance for specific applications is important to consider when building a motor. if you mean to ask "are the 2mm seals in the RENESIS thick enough to take some serious boost", i'd say yes, as they're at least as good as the Genuine Mazda seals in the 13BREW (i dunno if they're the same or not... certianly not worse), and those have seen some extremely sick levels of horsepower, and seal better at higher rpms than the heavier 3mm seals.
welcome.
UHATEIT
Mar 31, 2019 05:31 PM
projectr13b
Mar 1, 2019 09:00 AM
1.21 gigawatts!!!
Feb 14, 2019 03:23 AM
GracefulShanks
Aug 18, 2015 11:40 AM
groll69
MW RX-8 Forum
Aug 17, 2015 04:21 PM
