Ipod UI on Icelink Plus
Old Apr 23, 2005 | 12:37 AM
azharo's Avatar
Does anyone out there know how to switch to the Ipod user interface when using Ice link puls? I must be missing something trying to get it to change. Any help will be appreciated.
Old Apr 23, 2005 | 02:10 AM
jbrasure's Avatar
Use your stereo to switch to disk 6. This will display the IceLink menu on your iPod. Then press the track up or down button several times on your stereo until you select the "iPod UI" menu item. Once that is selected, press >> on your stereo.
Old Apr 23, 2005 | 09:18 AM
azharo's Avatar
Jbrasure.
I will try that again. There seems to be a few seconds delay for the track to change when you use the denison UI. Is this normal?
Old Apr 23, 2005 | 11:38 AM
kachud's Avatar
Mad Scientist
If you don't have enough playlists loaded in your ipod you may need to switch the to a lower disk number. I have 4 playlists and I access the "iPod VI" menu using disk 5. Be sure to update your firmware on your ipod to 2.06. It works much better than 2.05.
Old Apr 24, 2005 | 12:55 AM
jbrasure's Avatar
Yes, sometimes it takes 10 - 20 seconds before the IceLink menu appears. Also, sometimes I have trouble getting the IceLink menu to appear. It always works eventuallly, but seems a little flakey.
Old Apr 24, 2005 | 06:29 AM
kachud's Avatar
Mad Scientist
"Flakey" is an understatement :D
Old Apr 24, 2005 | 10:30 AM
azharo's Avatar
I finally switched to the Ipod UI and everthing is good now. You can still switch tracks with the steering but interface is much, much better.
BigMikeATL
May 26, 2016 12:31 AM
Nisaja
Series II Interior, Audio, and Electronics
Nov 3, 2015 05:30 PM
BigKid
Sep 23, 2015 07:46 PM
nivong
Europe For Sale/Wanted
Sep 2, 2015 07:54 AM
BigKid
Gulf For Sale/Wanted
Aug 13, 2015 12:40 PM
