If I turn my Canzoomer to the off position
Old Apr 15, 2005 | 10:27 AM
MDRX8's Avatar
If I turn my Canzoomer to the off position what happens. What Map will ir read? The lastest Mazda installed or the last canzoomer map installed?
Old Apr 15, 2005 | 11:07 AM
smrx8's Avatar
the car will go back to stock
Old Apr 15, 2005 | 12:11 PM
Nemesis8's Avatar
Bigus Rotus
I suggest resetting the PCM in the process also incase your LTFT has changed any.
Old May 26, 2005 | 01:42 PM
RX-8 friend's Avatar
The "on/off" switch disconnects the CZ unit outputs from the car's PCM, so it has no effect on the car. The car returns to "stock" PCM operation. I recommend turning off the engine before operating the switch. We haven't had to reset the PCM when doing this, and we do it all the time (as part of our testing procedure).
Old Jul 11, 2005 | 10:41 AM
Rotary Rasp's Avatar
503wtq Boosted Bimmer
If the CZ unit is turned off, is there any way for the dealer to know it is installed or if it is removed from the car before the dealer services it, is there any way they car tell it had the CZ unit installed?
Old Jul 11, 2005 | 12:31 PM
r0tor's Avatar
my car got flashed with my CZ on - all its doing is altering the maf sensors voltage so while the car is not running its really not doing anything and isn't detectable.
92trbolzr
May 18, 2025 09:04 AM
cliffkemp
Dec 24, 2024 10:48 AM
Shankapotamus3
Mar 14, 2021 03:53 PM
D13
Oct 1, 2015 07:55 AM
Racingjunkie
Sep 29, 2015 05:05 PM
