My custom fiberglass box
Old Apr 14, 2005 | 06:54 PM
Kevin239's Avatar
This is a fiberglass enclosure that me and my friend made for two 12" pioneer premier subs and a 500 watt JL audio amp.
This was our first attempt and i was pretty suprised and satisfied with the end result. Im going to start building a new fiberglass box with a different setup on monday.
This stuff was alot of fun even though it was time ocnsuming but it was worth it.
Heres a few pics
Attached Thumbnails My custom fiberglass box-dsc00001.jpg   My custom fiberglass box-dsc00002.jpg   My custom fiberglass box-dsc00005.jpg   My custom fiberglass box-dsc00006.jpg   My custom fiberglass box-dsc00008.jpg
Old Apr 14, 2005 | 07:03 PM
LiL BenNy's Avatar
Bubblicious? DEF.
nicee, did you paint it yourself?
Old Apr 14, 2005 | 08:39 PM
Kevin239's Avatar
yea i painted it. I had to use paint from a spray can but im going to buy a spray gun and everything for my next project.
Old Apr 14, 2005 | 08:49 PM
LiL BenNy's Avatar
Bubblicious? DEF.
YOU USED A SPRAY CAN!?!? what kind of paint! that looks AWSOME. im in the works of building mine and idk how i wanna finish it.. i was goona paint it but the air compressor and spray gun is too much... can you explain how you did this??
sand > body fill > primer > sand > paint >sand > paint> sand? somethign like that right? or you did something else please explain!!
and u used spray can paint but didnt spray it? am i correct? please go in depth!
Old Apr 14, 2005 | 09:47 PM
TRU681's Avatar
Looks good!
Old Apr 15, 2005 | 01:02 AM
Kevin239's Avatar
noo. i did spray paint it. sorry for wording that weird. I was thinking asbout covering with matching carpet but decided painting it would look much better.
These are my steps: sand > bondo'd > sanded > filled in with more bondo > sanded > filled in little pin holes with bondo type stuff > heavy coat of primer to fill in any imperfections > wet sanded > 2 coats of red paint > then finished it off with "gloss" spray paint.
Like i said, this was my first time ever messing with fiberglass/bondo/paint. but it worked out good and i was happy
Thanks for the comments man, good luck on your install, keep me updated.
Old Apr 15, 2005 | 03:24 AM
mikeb's Avatar
100% Italian
very nice
Im jealous
good job
Old Apr 15, 2005 | 05:21 AM
mr2000x's Avatar
pro_digi
yo that's what i'm talkin about - looks originally rude!
Good luck with the rest of your try outs - looks awesome
Old Apr 15, 2005 | 10:33 AM
canaryrx8's Avatar
looks cool, you got a lot of "dead space" in your trunk with that set up, from the looks of things if you were to redesign everything with better utilization of space you'd have a sick setup, nice work on the paint
Old Apr 15, 2005 | 10:43 AM
Kevin239's Avatar
Any body have any ides for what my next setup should be like?
Ive seen some setups where the person builds their box to fill the whole trunk, so its permanent and canot be removed.
But the way i would want to do it is build like 3 or 4 seperate pieces and slide them in the trunk, but they will also be removable.
Ive got a setup in mind that i will probably start monday. Ill keep yall updated on it.
Thanks again for all the comments.
Old Apr 15, 2005 | 10:13 PM
LiL BenNy's Avatar
Bubblicious? DEF.
hey can you tell me what kind of paint, primer, and gloss you used? like what brand and all that info ... thanks
Old Apr 15, 2005 | 10:27 PM
Kevin239's Avatar
Primer -
rust-oleum Painter's Touch sandable primer
Paint-
Krylon brand
Gloss -
Rust-oleum Painter's Touch
Old Apr 16, 2005 | 12:17 AM
jenkins-crew's Avatar
Take progressive pics of next project, I have always wanted to play with this kind of stuff!
Old Apr 16, 2005 | 01:32 AM
looks pretty good...next you should somehow incorporate your amp to it... =)
Old Apr 16, 2005 | 09:12 PM
Kevin239's Avatar
Yea ill be sure to take pics of my next project which should begin soon. I may add another sub and amp. still thinking though.
later
Old Apr 17, 2005 | 01:46 AM
LiL BenNy's Avatar
Bubblicious? DEF.
keep us updated! still in the progress of mine... check it out in the DIY section
Jazzmeson
RX-8 Multimedia/Photo Gallery
11
Mar 2, 2016 02:25 PM
Danield97
Sep 30, 2015 05:59 PM
mitchrx8
Sep 13, 2015 08:05 AM
